Trim Removal Tool?
Abramovich
Arizona
2021 Sport S (Chief) and 2022 Willys XR (Gobi) ord
I've seen many references to a trim removal tool. Can you share what tool you use and if you like it? Best tool to buy? Or are they all pretty much the same? Thanks for your help.
BDinTX
Dallas, Tx
NJJeep Guy
New Hampshire
2020 Hella Yella JLU
I think I got mine from Advanced Auto Parts. Set of 6 different pieces. Mostly find the simple straight stick the most common choice.
dsgrey
2019 JLU
Ormond Beach, Florida
Retired at 55 ..
JSFoster75
Bluff City, TN
cbroadway
Chad
Garden City Kansas
'76 Cj7 '16 Wrangler '18 Wrangler '22 Wrangler
sales
Funny story, a friend of mine that worked in a bike shop would always grab these plastic pieces anytime he'd see one in the grocery store. It's the part of the milk jug handle that usually gets punched out at factory, but sometimes one will get past. He liked using them to mount and dismount bicycle tires from rims because the plastic is rigid, but flexible, and gentle enough to keep from scratching anything. I'm sure it would work equally well on prying plastic trim pieces .
Jeep Wrangler JL Trim Removal Tool? ry1be7z7yjk01
jjvincent
Bethlehem, PA
2021 Wrangler, 2017 VW Alltrack, 2003 VW Eurovan
Mechanical Engineer
The trim tools from Harbor Freight work fine. If you are doing trim removal all of the time then I would go elsewhere. As for Jeeps, they seem to have an overabundance of door panel clips. So just make sure where those clips are when you remove the panel. That way you don't break where the panel holds in the clip.
Eyeball
1997 TJ & 2023 JLUR
I find myself using this aircraft skin prybar more often than I use my nylon trim tools. It is finished as smooth as silk with rounded edges. It works the same as nylon tools but has more strength. It can be used to pry things over, up, down all with absolutely no marring of the objects.
They cost a bit more but will last a lifetime.
Jeep Wrangler JL Trim Removal Tool? IMG_0706
[DELETED USER 82058]
Alabama
2022 JL Rubicon 2-Door
Harbor freight and I recommend some automotive wet sanding sand paper to smooth some of the rougher edges.
