Transmission Failure?
Jljohnny
Everett, Washington
2018 JL Rubicon
2020 JLUR 3.6 AUTO. 1000 miles on it. I was just moving the jeep out of the driveway, put it in reverse out on the street, and got nothing. In drive it is stuck in 2nd gear only! I tried the off and on several times. Check engine came on. I limped to the dealership 1 mile away, they pulled an active code p1d92, or is it pid92? Any ideas what's going on? I've only had the jeep 23 days, and it's also been in for cam sensor replacement.
Jeep Wrangler JL Transmission Failure? 20190923_130204
JeepCares
Auburn Hills, MI
JL
Hi John,
We're sorry to learn about your experience with your new Wrangler. If you would like, we would be happy to connect you with a Case Specialist to work alongside your dealer. Our team is available via PM.
Alex
Jeep Social Care Specialist
Hudson
PNW
2020 JLR
I just had the same issue on my 2020. Pulled out of my driveway and within 300 ft the transmission suddenly feels like it’s in neutral - the engine revs but no forward motion, and the check engine light came on. I stop, shift into park, and then into drive, same thing -engine revs but no go. The radio screen reads ā€œplace in parkā€ or similar. I shut Jeep off, turn it back on, start it up and everything is fine.
I ran my OBD reader and it showed two error codes: P1D98 and P1D92. Cleared the codes and so far, no issues.
what was your diagnosis? I’m guessing there was some kind of odd fault code that may have been the transmission software throwing a fault. Very odd.
nerubi
Nebraska
2019 JLR, 2020 VW Tiguan
P1D98 CHRYSLER Meaning
The Transmission Control Module (TCM) monitors for conditions which lead to an unexpected transmission gear ratio (e.g. slipping clutches, hydraulic or mechanical defects, etc.). The TCM compares the actual gear ratio (i.e. the ratio of input speed to output speed) to a minimum and maximum calibrated gear ratio value. The TCM performs this comparison while driving in a fixed gear, during gear engagement, and during shifting from one gear to another.
P1D98 CHRYSLER Possible Causes
What does this mean?
  • Faulty Transmission Internal Components
P1D92 - Incorrect Gear Ratio Clutch 4 Defective
Please don't say they are now going to have problems with the automatics also.
JeepCares
Auburn Hills, MI
JL
Hello @Hudson
We are sorry to hear about the recent troubles you've experienced with your Jeep. If you continue to notice these concerns, please feel free to message our team privately. We would be happy to offer additional assistance alongside your dealer.
Kathryn
JeepCares
ToPar9
North Texas
'19 JLU Altitude
I’m glad I ran into this thread.
This happened to me as well.
I received the same fault, explained to me as a cam sensor fault. I dropped off the Jeep on Friday. I’m told they can’t get to it until late Monday, early Tuesday at the earliest.
Any additional info on your fix, what was broken, continued problems?
appreciate it in advance.
Bane_JL
Christopher
Fort Campbell
2020 Jeep JL Sport
I had this issue two days ago. It was the valve body and PCM a needed updating.
photo2000a
NYFL
jeeps,gofastcars,luxcars,oldcars,junkers
Engineer, Fashion Photographer, Go fast driver
I had my transmission replaced few thousand highway miles. 19 jlru.
JeepgirlJL2018white
Andrea
Buford, GA
2018 JL unlimited
Jeep Wrangler JL Transmission Failure? 16007104147846097234215303738299
JeepgirlJL2018white
Andrea
Buford, GA
2018 JL unlimited
do NOT WAIT A MOMENT! I complained for 2 years about my transmission. At 65,000 after warranty very gear went out while driving on highway. If you get incorrect ratio gear take it over and over and over to dealership. Do clear them until you find issue. Cost me 5,200. Dealership kept saying there wasn't an issue.
Adam 4248
Washington
2018 JLS
I also had that code; my Jeep also had metal shavings in the transmission pan. The trans was replaced, but it is not the same...
Swissswiss
Bay Area
2021 2dr sport s v6
Curious how it’s running now that it’s fixed. Same thing happened to me at 1000 miles and I’m trying to get back confidence that it will work without issues when returned
OllieChristopher
Southern CA
2005 GMC 2WD Sierra, 4.3, NV3500, 3:73/TruTrac
It just burns me what dealers do to try and deny claims. "Inspected for damage or abuse of vehicle and none damage or abuse could be found"". What a crock. I have never seen this crap before on a warranty claim. The grammar is wrong and of course it's damaged or it would not have been replaced.
I had my transmission replaced under warranty at just under 100,000 miles no questions asked. Got my truck towed in and had transmission replaced in a day. Nowhere on the paperwork was this stupid nonsense. This is disgusting. Why even get a Jeep Wrangler and take it off road so they can claim you are abusing it?
