transmission and limp mode need help
Nizar
Israel
JK
hi, desperate for help since my jeep is driving me crazy for sometime and I an stuck, issue started while driving got Christmas lights and all kind of errors and jeep went into park mode and could not drive, had to toe to the garage, few days later after replacing both batteries and checking everything electric and connectors and after a reset the jeep drove ok for a few days, then deleted the aux battery and the fuze and all was ok then again the same problem and it only shows error code u0101 and the transmission temp goes up to 205c degree.
if relevant the jeep has tazer, 35inch tires, winch an ARB compressor, all connection point and electric points got checked and eliminated during the investigation
the jeep is 2022, the and is not subjected to the heat exchanger known issue it uses the new part.
we are wondering if anybody was hit with this and what was the fix, is this an electric cable problem? a lose connection point ? grounding point? a transmission? a dcm or whatever computer issue? or a mechanical problem with the grar?
why the problem only appears randomly and no real way to reproduce it, sometimes after 2 mins drive the error goes on sometimes after 4 days etc..
we are really stuck and looping for help on whats best way to diagnose and eventually solve the problem
thanks team
EbyCreek
Troy
Eagle, Colorado
2021 Wrangler 392
ARMY (Retired) UH-60 ME/IP
First thing I would do is unmarry & remove the Tazer. Probably not the problem but it is one of the easy things to try. After that I would replace the green star connector behind the glove box.
Nizar
Israel
JK
hi, thanks for the quick answer. the tazer was unmarried and removed and this green connector was checked but not replaced.. is it common for this connector to fail? anything else to check ?
EbyCreek
Troy
Eagle, Colorado
2021 Wrangler 392
Somewhat common when you are experiencing electrical problems.
Remorseless
NC
The other part that often comes up in these weird electrical gremlin threads is the high amp fuse array near the main battery and the wire harness behind the front passenger fender. The high amp fuse array can sometimes blow and cause weird issues. The wire harness behind front passenger fender can sometimes wear through and cause glitchy electronics, often related to transmissions.
azjl#3
North AZ
canbus issue behind glove box door?
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Yes common to fail. Just replace it, there’s no other way to know. You can sometimes disassemble them and find a little burn spot on the circuit board inside but often it looks just fine.
HeN2O2
Shell Beach, CA
2023 JL Rubicon Diesel; 1983 CJ-8
As best as you can, check the wiring between the transmission and the ECM. There is a wiring schematic somewhere on this website. Some models have had issues where the harness runs close to the exhaust system and need more insulation.
Also check the ECM wiring harness, first for obvious signs of damage, then gently touch the wires at the ECM while the engine is running. I had two loose connections in the ECM harness that would act up when it was cool and damp resulting in a bunch of nonsensical can bus errors. As the connections got worse, hitting a bump or rough stretch of road.
Somewhere on this website is a good description of ground points. A loose ground could cause your problem.
If all else fails, youths in Asia may be the only solution. You can borrow my M2HB to get it done.
Nizar
Israel
JK
thanks, what do you mean by bypass power/ground around the connector?​
FireAnt21
Tony
Wisconsin
2020 Sahara Unlimited North Edition
Lineman
r/f fender liner inline connector for the transmission. bypass the power/ground for the trans around the connector
Can you post a pic of said connection
alphawolff
california
2021 JLU
no, but there's quite a few threads about it on the forums already. remove r/f fender liner and you'll see a big connector along the firewall that goes to the bellhousing area. you'll want to cut and solder the power/ground wires around the connector. there's a 12v and a pink/yellow ignition run for power and a black wire for ground.
Terrymo
Terry
2023 JLURXR 3.6 ET
If it’s in either of these two pics could you point it out? i have my inner fender off to run some wiring.
Jeep Wrangler JL transmission and limp mode need help IMG_2256
Jeep Wrangler JL transmission and limp mode need help IMG_2255
