nU7OuxIx
I have a trailer that I ended up changing the bearings on. One side there was a lot of play in the tire. The other side there was no play but yet I figured why not change both.
For what it's worth, I used Timken's set 12 and set 13 for the bearings. I watched tons of youtube videos on how to preload. Once installed, I tightened down that castle nut until there was no wheel spin. Loosened and spun the wheel. Tightened and repeated this process a handful of times. When finished I put the castle nut on tightly by hand. After putting the wheel on and taking for a test drive, there's an extremely small amount of play when I shake the tire.
Should there be zero play when the trailer is jacked up and I shake the tire? You can feel the play but not see it.
