Traction Control turning off
aeonixx1001
Kim
Arizona
2020 Jeep JL
Let the Jeep go into deep sleep as in walk away with the fob for at least 90 seconds? I assume it's ok to get back in with the fob afterward if we need to start it immediately.
Yes, walk away for a couple minutes. Fob in hand get in stepp on accelerator twicee fairly hard and fast and then just start it.
Reinen
Reinen
2021 Jeep Wrangler JL Rubicon
That didn't work for me. The Jeep sat overnight for 4 days before deciding to work again on the 5th day.
aeonixx1001
Kim
Arizona
2020 Jeep JL
The other thing he said to try if the first attempt didn't work was to disconnect the negative battery terminal connection from both the primary battery. Or the sensor really bad and needs replacement. You can go to the parts store and they have a handheld tester hooks onto your ODB and tells you the fault.
