Reinen
This may be near impossible to track down at this point but in case anyone has any ideas...
The issue is Traction Control turning off after 30-90 seconds while in 2WD on smooth roads.
It started happening after an overlanding trip which involved splattered thick dense mud and a water fording in 4WD LO. The water fording was deep enough to submerge axles but definitely not enough to exceed the Max Water Fording Depth. No symptoms while off-road. Upon leaving the trail and returning to 2WD "highway mode", Traction Control would turn off after 30 seconds to 2 minutes. No other symptoms. I could turn it back on but it would quietly turn off again as if I pushed the button but didn't.
Upon returning home I washed the mud off the Jeep with a cursory spray to the undercarriage, but not a thorough spray. Traction Control continued to turn off for 4 days but seemed to take progressively longer to turn off. By the 5th day it stayed on and has been fine since.
After it cleared up I finally got around to pulling codes with a Tazer JL Mini. (yeah, I know. A day late and a dollar short. Life got in the way.)
BCM U1514-87 - "Engine Controller Secret Code-Missing Message"
PTS U0415 - "Invalid Data Received from Anti-Lock Brake System (ABS) Control Module"
Since it happened right after a water fording and stopped happening 5 days later, I'm thinking that I'm having some water intrusion on an undercarriage sensor connection but I'm not sure which one. Wheel speed sensors come to mind but I've had a wheel speed sensor issue before and it did a lot more than just quietly turn Traction Control off and post a communication code.
Any ideas of how to pinpoint the issue and prevent it in the future?
