Towing the 4xe!
coachakpenrod
Ohio
Jeep Wrangler 18
What is the best Blue Ox for cost flat tow setup for a new Silver 4xe? I already have tow bar — just need wiring and base plate correct?
Twojayhawks
Bill
Lenexa Kansas
2021 JLU Sport Altitude
business owner
Since no replies I'll go ahead. If cost is your biggest hot button you should look at the Maximus tow loops. At about $300 I believe they come in under a Blue Ox base plate. I used the Mopar flat tow wire harness, Maximus tow loops, and ReadyBrute tow bar. Of course if you already have a tow bar you likely already have clevis's on the bar for a (Blue Ox) base plate? If that's the case it might be better to just stay with BO. If you used the tow loops you will need the clevis's specific to them.
Down South
Sam
Louisiana
2020 JLUR
One of the best places to check components needed for flat towing is Etrailer.
Get what you are comfortable installing yourself.
They have several different base plates, wiring harnesses, etc.
Etrailer
Best of luck...
