too smooth into 4lo?
drivingfool
KMLB
2023 4XE Rubi
Picked up a '23 4xe rubi on a good deal. No hits on the underside (no big scrapes, everything's straight, diffs are not shaved, etc). 15k miles. It has that new fulltime/parttime 4wd transfer case.
My concern is that it VERY smooth into 4lo. I don't hear any gear whine, and it's bone stock.
I'm bringing it in for a full fluid check for glitter.
This is my 4th wrangler and I've never felt a jeep this smooth into 4lo.
At a glance, what do yall think?
roaniecowpony
Retired Engineer
Can't you just take it in some sand or dirt and check to see if it's working? Even put it in 4Lo on pavement and try a turn. It should buck and slip the tires if it's in 4Lo.
roaniecowpony
Retired Engineer
If it doesn't go into 4Lo, it could be a shift fork. Also, check the cable.
TheBirdie72
Rhode Island
2021 Jeep Wrangler Freedom Edition 2 Door
She shifts into 4Lo too easily you say…?
You know the rule: If she seems overly flexible on the first go-round with her, she’s either a gymnast or very well in practice recently. Just sayin’. ?
(Probably not her first go round in 4Lo)
roaniecowpony
Retired Engineer
cable?
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
If I gave you a five-dollar bill would you complain that the serial number doesn't start with your favorite letter? My JLR goes into 4-low very easily, smooth as butter. Make you feel butter <sp>?
Bleda2002
2021 JTR, 2021 Sahara 4xe
Its because its the awd transfer case. It uses clutches instead of unsync'd gears like the part-time transfer case so it is really smooth/easy to engage.
