Tires
longfiredragon
Darryl
Cocoa Fl.
2021 JLUW Sport 2.0 L Turbo
Just hoping someone can refresh my memory. I have 2021 JLU Willys. It has a 2" spacer lift. I should be able to run the stock Rubicon size tires 285/70/17 correct?
And 2nd will the 285/70/17 fit on my spare tire carrier?
Thanks
aldo98229
Aldo
Bellingham, WA
Market Research
With a 2-inch spacer lift you should be able to fit 285/75R17 without rubbing if you wanted. That’s 34x11.2 inches.
Not sure if a 34-inch tire spare will clear the bumper with the OE carrier. But you can get a Smittybilt spare tire relocation bracket for $100.
Good luck.
2nd 392
Ca
Another option if relocation is needed and you want to keep weight down is Teraflex aluminum brackets , maybe a couple lbs instead of 11-14 lb steel ones. ~$150. They come with a tailgate bumper spacer kit so that’s covered, 6 in 3 sizes .
Megawatt
Sin City aka Vegas
money pits: Turbo Busa, Street Bob, 22JLUR snazz, 5.0 mustang MT
Powerplant operator
I put on 35” on my stock spare tire carrier. It fits just fine.
I did have to do the “rotate the spare tire” (once) to get rid of the right side vehicle present alarm when backing up that appeared after the upgrade.
