Tires/Wheels Rubicon vs Gladiator
WrangleDangle
Atlanta, GA
2020 JLUR
I have a 2020JLUR-
I'm trying to find take-offs for it.
Are tires/wheels combo from a Rubicon or Gladiator inter-changeable?
Thanks for any advice-
Cunky
NYC
2022 Wrangler Unlimited Willys
Yeah you should be fine. I don't think there are any Gladiator trims that have stock wheels/tires that wouldn't fit a stock Rubi. The Mojave has a slightly different offset but it would still fit just fine. They all use the same lug pattern 5x5.
One thing to note: Gladiators have 4 tires with their apporporiate trim level wheels. The spare is on a steely. So in general, a set of gladiator take-off will require you to buy a matching wheel or just use 4 with a non-matching spare wheel. Also if you buy take-offs with TPMS you want to make sure it will work with your jeep otherwise you're just going to have to replace them.
Deleted member 59498
Guest
Seen one or two JLs around here with the steel gladiator wheels they look great. So yep should be no issue.
WrangleDangle
Atlanta, GA
2020 JLUR
THank you for the information.
WrangleDangle
Atlanta, GA
2020 JLUR
Does anyone know if the TPMS in Rubicon wheels is the same as the ones in the Gladiator wheels?
R3TRO
Pasadena, CA
'20 Jeep Willys
Film Industry
I put Mojave Gladiator wheels on my Willys with no issue. I believe the offset pushes them out a tiny bit, but they are still even with the fender, no poke. Found a great deal on 4x take-offs with MTs, but did have to source a single wheel and tire for the spare.
Jeep Wrangler JL Tires/Wheels Rubicon vs Gladiator 1694460277004
Jeep Wrangler JL Tires/Wheels Rubicon vs Gladiator 1694460340735
Jeep Wrangler JL Tires/Wheels Rubicon vs Gladiator 1694460390721
Jeep Wrangler JL Tires/Wheels Rubicon vs Gladiator 1694460455771
6th Floor Mule
Keith
Woodstock, GA
2018 JLU Sahara 6MT
I have a 2020JLUR-
If you go with 4 of the below and need a matching 5th, let me know. I have a couple gathering dust in my basement.
Jeep Wrangler JL Tires/Wheels Rubicon vs Gladiator IMG_0184
WrangleDangle
Atlanta, GA
2020 JLUR
I may end up needing 1 or 2 maybe, just for my info, how much$ do you want for one and where are you located at?
Thanks-
