Tire recommendations please
Pres2032
LJ
Miami, FL
2024 Jeep Wrangler Sport
Just bought a 2024 Wrangler Sport 4dr. What are the biggest, toughest looking tires I can replace my stock tires with, without lifting it and while still using my stock rims? This will be 100% for street driving, no off-roading.
Thank you in advance!
jludave
The Isle of Long
IT Manager
I guess it's a right of passage that every jeep and pickup owner needs to go through. Usually, the subject is cured of this condition after a couple thousand dollar lesson.
"off-road tires" are called that because they are intended for off-road use. They suck on-road.
azwjowner
Phoenix
Well, you're looking at 285/70R17 tires then. That is the largest you can fit without lifting and on the stock wheels.
As far as the "toughest looking tires," that puts you in the category of mud terrains. Probably the toughest looking tire that is readily available will be the Gladiator X COMP M/T: https://www.walmart.com/ip/Gladiato...045263825?wmlspartner=wlpa&selectedSellerId=0
Beware, all mud terrains are noisy, and the tougher they look, the noisier they are and the rougher they ride. But that's what you want.
J.Ferreira
Castle Rock, Colorado
www.tmgps.org
1999 Jeep XJ
Well, with some 3" thick spacers and taking the fenders off, you could probably run 37" tires, or more if you trim the pinch welds.
Jeep Wrangler JL Tire recommendations please s-l1600
Pinion
Rob
Hull, MA
1971 FJ40, 22 Rubicon Unlimited
Project Manager
You should look into Thornbirds. They're great for where you live.
Nokones
Kenny
Sun City West, AZ
Then, why change the tires if your Jeep is going to be just a grocery getter especially with the factory wheels. It would sorta out of place if you went to a more aggressive tire on a grocery getting wheels. If you're wanting to change tires for obviously just for looks change the wheels. If your grocery getting tires are still round use them.
yokramer
Snark Incarnate
Jeep Wrangler JL Tire recommendations please 1714483935510-8u
grandsrus
DFW, TX/ Melbourne, FL
2019 JLUR
Aerospace
243/82/18.4 ftmfw!
