Tire rattle?
cwadle
cameron
Rochester Hills, MI
2019 Granite JLUR
I can't quite narrow down the exact source of the noise, but I figured maybe some of you might have. It seems at decent speeds 30+ I have a distinct clicking sounds consistently from the outside of the car. I assumed it has something to do with the suspension system or maybe a contaminated break pad, But I haven't found anything yet. Hopefully you guys have ideas?
JeepCares
Auburn Hills, MI
JL
Hi cwadle,
I certainly understand why this would be concerning. If you are not able to pinpoint the root of the concern based on advice provided here, I kindly recommend connecting with your local Jeep dealer. Our team is available via private message if you are in need of any assistance with that process.
Jeep Social Care Specialist
wranglerguyman
Long Island, NY
JLU Rubicon
That sounds like a tiny rock is wedged in between your tire threads.
OldBird
Timothy
Washington State
2019 Mojito! JLUR
If you're not used to having AT tires you might not recognize the little annoyance of rocks in the treads. I find that the KO2s in particular tend to pick up little rocks and not let them go. You either learn to ignore it or walk around picking little rocks out of the treads all the time.
cwadle
cwadle
cameron
Rochester Hills, MI
2019 Granite JLUR
I never thought about that, this is my first car with all terrain tires. I will check my tread tonight, hopefully that solves the problem. Thanks !
Blu bi Kong
Vic
Colorado Springs
2018 Rubicon JL
Open back, lift up cover that covers jack. Mine was loose when I bought it. I simply turned the mechanism to tighten the jack within the space. Problem gone. Now jack gone anyway
cwadle
cwadle
cameron
Rochester Hills, MI
2019 Granite JLUR
will definitly check that too thanks!
Maverick909
I.E.
www.instagram.com
could be a nail in the tire too. just pulled one out lastnight from the MT's gotta love it
cwadle
cwadle
cameron
Rochester Hills, MI
2019 Granite JLUR
Found the little thing stuck in my tread, worn down to a flat surface. Must have been it. Mostly just glad to see there is no mechanical issue.
