Tire Deflaters
Terrymo
Terry
2023 JLURXR 3.6 ET
On a side note I think the forum is having a meltdown because I got a notification you quoted me but your post is actually quoting @Rotsam. And if I hover over @Rotsam's username in the post my profile comes up.
Either that or @Rotsam and I switched bodies somehow and maybe he's actually the one who came back from Texas all those months ago. šŸ˜‚
LOL…senior moment…I put your user name reflexively after seeing the blue Jeep on @rotsom profile pic then realized I messed up and edited my post. That’s my story and I’m sticking to it.
SadRobot
Los Angeles
2025 Prius LE
In the right light they do look pretty similar. Ha or they did before his got built up on 40s. 🤣
Jeep Wrangler JL Tire Deflaters IMG_4376 copy
KELove
Kent
Matthews, NC
2018 Wrangler Unlimited JL Sahara
I use Staun, had them since 2018. They work great, are adjustable and came preset at 18lbs.Got them on Amazon.
Andy@AAV
Virginia
2022 Gobi 4XE, 2010 Toyota Tacoma
UxS Engineer
Been using Stauns for a decade. I set them to 20 psi by trial and error then set the lock rings with loctite. There are probably better options but I already have these and I’m used to them. Are they always 100% accurate? No, but close enough for me since they are my default dirt road setting. If I need to go lower I pull out my old ARB deflator.
Fleeclan
Loren
Cedartown, GA.
2021 JLUR, 1978 CJ-5
I finally gave up on deflators and installed the Apex Rapid deflator valves. Air down from 30 to 10 in about 10-12 seconds.
I have been trying to get a set of 4 tire deflaters that work. The ones I have only lasted a few times and won’t stay adjusted anymore. I even took them apart and tried to clean them. I would like some recommendations on ones that work and not a waste of money. I checked Amazon and it wasn’t any help. What is working for you?
Odyssey USA
Daniel
www.youtube.com
2021 JLU Rubicon
If I try anything else besides pulling the core, I think this might be a direction I try. Do you know if they will work with stock wheels?
Grayhound
Michigan
Jlurd
I just run my cheapies wide open and watch the pressure gage on the dash. Sometimes I’m running pretty fast to get to a tire but it’s pretty quick and pretty accurate. Just gotta stay engaged in the process.
AmericanPatriot100
Kitsap Co
2025 Wrangler Sport JL
I know our jeeps have that tire deal on the radio apps, does anyone know how it works? I’ve tried to use it but the button is greyed out on my screen like it’s there but not available?
azjl#3
North AZ
Used rhino deflators yesterday 1st time on OBX. Set 18, got 18, 18 15, 19. How does my contact patch look? 😊
Jeep Wrangler JL Tire Deflaters 1000003141
Kip
Kip
Long Beach Ca.
2018 jlu Rubicon
You can see the tire pressure by using the buttons on the left side of the steering wheel. I find it very slow to respond to the pressure change.
UTME
T
2024 Rubicon-X Unlimited
been using Stauns for many years...took a little to get them all set but once set they have been bullet proof for me...
Same here!
Fleeclan
Loren
Cedartown, GA.
They will work with stock wheel. Just make sure you get the shorter version. The longer version is for a deep stem bore. They also accept your OEM pressure sensors.
