Through shaft stabilizer
CarbonSteel
2023 Ford Bronco Wildtrak
Thanks man...... if my pan head bolt doesn’t work I’ll hit you up. Why did you switch it out?
I did not like the look of it and though there is likely not a lot of pressure on it, I wanted a heavier duty bolt than the one they supplied and the flange of the pan head does not cover much of the stabilizer end.
Roky
Roky
Roky
Gotcha..... I’m using it on my set up now, so far no issues, but I didn’t know if the through shaft was different or not where it might not work with it.
oceanblue2019
Maryland
2019 JLUR 2.0L Auto
Metrology
So your saying that I am I going to be able to use my synergy track bar bolt with the little pan head Allen bolt?
Yes, what I am doing currently. Use the two step washers that come with the FOX ATS on the Synergy stud. It all fits together fine.
