AndySpill
- Andy
- Oct 24, 2023
- Pittsburgh
- 2018 JL Sahara
Here's what I *think* happens. The cold crank test happens and the first time you try to crank after disconnecting the Aux battery, but keeping Fuse 42 intact, the rig doesn't crank. For that point on the test of the Aux battery still happens (I think) but in failure to acquire power solely from the Aux battery the JL's programming chooses to then continue on to deenergize the relay that separates the batteries, controlled by Fuse 42, and attempts the crank off the main battery.I run one battery and hit the ESS off button the first time I think about it. I have considered buying one of the stop/start off devices but I can't bring myself to write the check.
I've tried driving with the aux battery disconnected and the F42 fuse in. It works like you say. I don't mind the "Avenger" light just above the gas gauge. What I don't like is the message screen displaying "service stop/start system" while I drive. I believe that this message will always appear on start. A driver can scroll away from the message which is almost the same as turning off the stop/start using the button every time you drive.Unknown for me is if the constant "service stop/start system" will prevent a driver from seeing another more important message. Also, in the event that a Jeep driver ever has to take their vehicle in for service, chances are the service tech is going to react to the "service stop/start system" message.
FWIW, I believe that my Jeep, the one where I deleted the aux battery and removed the F42 fuse, operates exactly as designed except for the cold crank test. I think the cold crank test is still made, it's just that there is no battery separation step. The cold crank test sees the main battery. In the event the main battery fails the cold crank test, the Jeep probably would not start anyway. Boosting the Jeep (with one battery) should work just like the other cars and trucks I have had over the decades.
I am not certain. I am certain that this doesn't happen in early model 2018s that haven't been flashed. A dead Aux battery strands you.
And I believe this is the case because once you reintroduce the Aux battery into the power plant, on the next cold crank (I tried it) the ESS off light in the EVIC shuts off.
