The Moose is Loose!
BullMoose1776
BullMoose1776
Bull
South Texas
Project Manager
You get mopar lower CAs? Tighten the ball joint nuts?
Im going through the same issues.
Have not made changes. Other than the AEV lift and this AEV dampener
BullMoose1776
BullMoose1776
Bull
South Texas
Project Manager
Got a 5 tire rotation today by the good folks at @Discount Tire . They always treat me right!
Jeep Wrangler JL The Moose is Loose! PXL_20220219_144931290
Jeep Wrangler JL The Moose is Loose! PXL_20220219_144910244
BullMoose1776
BullMoose1776
Bull
South Texas
Project Manager
Finally got around to installing my ARB Dual Compressor under the Passenger seat in the Jeep. Pic for proof...not much to see. I don't take pics along the way with anything.
Wiring was not easy, but I can tell ya, utilizing the drain plug, and running the wiring along the top of the frame rail is the easiest route.
I pulled the Genesis Dual Battery kit out, along with the Fuse Box, because I saw videos that said that was the way to go. Wrong.
I did wire in the compressors to the Aux battery, and I wired in the switch wires to the ignition wire in the Aux Wiring Package under the dash.
Super happy with this location, and can't wait to put it to use after driving on the Beach this spring!
Jeep Wrangler JL The Moose is Loose! PXL_20220221_023013782
sciotola88
Stan
Boerne
2022 Willys Ecodiesel and 2020 JTR
Underwriter
Beautiful rig. I saw you on the highway last week.
BullMoose1776
BullMoose1776
Bull
South Texas
Project Manager
Right on! We need a "Jeep City" designation for all the Jeep vehicles here in Boerne!
BullMoose1776
BullMoose1776
Bull
South Texas
Project Manager
Since installation of the AEV Steering Stabilizer I've gone on a 8 hour drive to another state.
After I installed I have a crooked steering wheel (turned to the right) but the tracking down the road on a flat road at 75-80 is great. That is a big improvement over the previous strong pull to the right.
I'm going to have an alignment done to straighten out the steering wheel, and hopefully be all set. Super happy with this upgrade.
grandsrus
DFW, TX/ Melbourne, FL
2019 JLUR
Aerospace
Good work I knwo this can be frustrating. It seems all minute changes to the JL have huge impacts.
I just moved my toe to absolute 0. Wow what a difference that made for the better.
It was 1/8" toe in. Need to get up to hwy speed to check wander now. It feels much lighter, if that makes sense.
BullMoose1776
BullMoose1776
Bull
South Texas
Project Manager
Finished the installation on the second set of four inch Rigid 360 Spot/floods. Second set is on the cowl.
1 set of these is very bright. 2 sets are VERY bright.
Jeep Wrangler JL The Moose is Loose! PXL_20220402_015144213
Jeep Wrangler JL The Moose is Loose! PXL_20220402_015002544
BullMoose1776
BullMoose1776
Bull
South Texas
Project Manager
Added on the last set of lights! I chose the @KC HiLiTES Cyclone 2 lights for the rock lights. I added 8 lights total, and changed the clear lenses for Red. I also added the magnets from KC, which are fantastic.
The quality of these lights is outstanding, and I'm very happy with the total package from KC.
Jeep Wrangler JL The Moose is Loose! PXL_20220415_012820751
Jeep Wrangler JL The Moose is Loose! PXL_20220415_012801215
Jeep Wrangler JL The Moose is Loose! PXL_20220415_012737178
Jeep Wrangler JL The Moose is Loose! PXL_20220415_012843829
Jeep Wrangler JL The Moose is Loose! PXL_20220415_012715661
KC HiLiTES
Rock Sponsor (Level 1)
Robert B.
Flagstaff, AZ
2020 Jeep JT, 1969 Wagoneer
Lighting Adventures Since 1970
The Jeep is looking great!
BullMoose1776
BullMoose1776
Bull
South Texas
Project Manager
Took some more pics tonight after re-positioning under the doors for a better spread, and later, with more darkness...WOW! 8 lights is pretty bright!
Jeep Wrangler JL The Moose is Loose! PXL_20220416_014731774
Jeep Wrangler JL The Moose is Loose! PXL_20220416_014615696
Jeep Wrangler JL The Moose is Loose! PXL_20220416_014755450
Jeep Wrangler JL The Moose is Loose! PXL_20220416_014820928
MyDaughters20JL
WA
20 JL Sport S
if you haven't already had the alignmfent done & the "off center" steering wheel is your only issue, it only takes a few minutes & a couple trips around the block to do it yourself.
my wheel was off after installation of my adjustable lower control arms, so after a short bit of research, fount a video on how to correct the problem..and it's so easy, even I was able to do it
BullMoose1776
BullMoose1776
Bull
South Texas
Project Manager
Found a great deal on a set of 4 red Mopar Half doors, so I jumped on it! Pics to follow after I travel 5 hours back home!
BullMoose1776
BullMoose1776
Bull
South Texas
Project Manager
These doors are great! Can't wait to have them painted!
Jeep Wrangler JL The Moose is Loose! PXL_20220501_001007027
Jeep Wrangler JL The Moose is Loose! PXL_20220501_000941611
sciotola88
Stan
Boerne
Underwriter
Looks great! Can't wait for my order to be delivered. The half doors are the first thing going on! (And then 37s)
