Testing the fuse array. Help!
Outdrluvr28
Blanchard, OK
2020 JLU
All,
I’ve searched google, this and the gladiator forum, and YouTube. I CANNOT find anyone or pictures/videos of how to actually test the fuse array. I’ve seen so many people comment on issues that are what I’m experiencing, and say to “test the array with a multimeter”….. I have a digital one, but I don’t know how to actually test the array as I would a relay or traditional fuse.
can anyone answer that has successfully tested the array, and how they did it? Please. Preferably pictures or a video?
I’ve installed two brand new batteries and replaced alternator, and I still get the warning that I need to park safely because the vehicle is going to turn off.
can anyone help guide meon a how-to test the fuse array?The year is a 2021.I really don’t want to take to a shop as it’s out of warranty now.
Thanks all. ??????
patternman
George
Phoenix AZ
2019 JLUS, 2014 & 2001 Indian
Set DVM to continuity, touch one lead to solid bar on top and with the other lead one at a time check for continuity at each of the tabs on the bottom.
Jeep Wrangler JL Testing the fuse array. Help! array
mwilk012
2018 Ocean Blue JLU Rubicon
Service
It’s just a bunch of fuses stuck together in one housing. There is nothing unusual about its construction or power distribution.
patternman
George
Phoenix AZ
I discovered I blew N3. Thanks so much. ?????
When you purchase replacement be sure to get the right one. There are at least 2 that I'm aware of.
You probably can find part number on yours.
Outdrluvr28
Outdrluvr28
Blanchard, OK
2020 JLU
Thanks.
thanks for the heads up! I actually discovered that. I did order the correct part/serial number. Thanks man. ????
mwilk012
Service
BTW how do u know it was n3? As I just did a wire job for hard top install and having issues. What did the n3 on fuse array cause for you? Ty
a blown N3 fuse will prevent the alternator from charging the auxiliary battery, which then creates a whole host of issues. This almost always happens when battery cables are disconnected incorrectly.
