Teraflex adjustable spare tire bracket?
mdkautzman
Centralia, WA
2021 Jeep Gladiator
Anyone using one if these adjustable spare tire bracket.
If so how much Gail in inches can you get from stock location. I need to clear an aftermarket bumper and tire 33" needs to go up at least 3".
Thanks.
BDinTX
Dallas, Tx
I put one on a week or so ago. I’m pretty sure it only went up about 2” from stock height.
baskiboat
Oregon
2021 Rubicon 4XE, Sting Gray
I think I got more than 2" I use it with 37's. I also have the HD tailgate bracket which I think moved it up.
Jeep Wrangler JL Teraflex adjustable spare tire bracket? 20220115_221634
Left Field
Tim
Western WA
'67 RS-SS Camaro, 2021 JLUR392
Recently installed one also; here's a picture from the installation instructions. There are three sets of height adjustment holes, and they appear to be 1-1/2" between each set. I've got the steel bumper and stock 33" tires so I'm using 'Hole 2' and there's a little over an inch of clearance to my bumper.
So with the 33's that's the inch+ of clearance and then another 1-1/2" for moving to 'Hole 3' for a total of 2-1/2"+ with the steel bumper. Daughter's ran off with the JL for a few days, but if you want I can get your the exact clearance of 33's when she returns.
If you are replacing a plastic bumper it looks like you'll get your 3" no problem.
Jeep Wrangler JL Teraflex adjustable spare tire bracket? Terraflex Mount
mdkautzman
mdkautzman
Centralia, WA
2021 Jeep Gladiator
Thanks everyone! Great responses and much appreciated!
BDinTX
Dallas, Tx
I think you’re making an assumption that the bottom most holes put the mounting studs in the same position as the factory ones but that pic says NA for position 1 with a steel bumper and stock tires.
My 315/70r17 was lightly touching the factory bumper athe bottom with the factory spare tire mount. It’s measuring now around 1.75” after the Teraflex mount.
Jeep Wrangler JL Teraflex adjustable spare tire bracket? BCB32137-08DB-420C-A86F-3D8AD3F29FDC
All that said, OP - are you sure you need 3” of clearance? It seems that would be almost even with the bottom of the tailgate.
mdkautzman
mdkautzman
Centralia, WA
2021 Jeep Gladiator
I'm purchased one of these mini numbers. This is what I need to clear.
Jeep Wrangler JL Teraflex adjustable spare tire bracket? Screenshot_20220116-074906
BDinTX
Dallas, Tx
Ah I see. I think it would work but I'd also be hesitant to buy something based on such a flimsy recommendation. You mentioned 33" tires, was that just for reference or will you actually be keeping that size?
mdkautzman
mdkautzman
Centralia, WA
2021 Jeep Gladiator
Keeping the 33" tires. Not looking to go any bigger.
Left Field
Tim
Western WA
I agree that 'Hole 1' is NA with the steel bumper - the tire would hit. I'm running the stock steel bumper w the stock 33's, so used 'Hole 2', which appeared to raise the tire just slightly.
Similar on mine, a 35" tire probably would have squeezed in using the factory mount but would fit easily in 'Hole 2'. So I agree that with the steel bumper there is only one remaining hole height to use, gaining a single 1-1/2" increment, which with the existing 1+ inch of clearance for a 33" gives the 2-1/2" number.
'Hole 1' as you suggest does confuse me. It appears to actually lower the tire? And is the plastic bumper that much lower (so you can use 'hole 1' and 33's?
Brad - do you recall which mount position you are using? I am planning on upping tire size, looks like you are good with at least 37-38" tires?
BDinTX
Dallas, Tx
Yep I’m in the top most hole
