Tazer JL vs Mini
wanderer
Ralph
Carlsbad CA
Engineering Geologist
I saw 3 listings for a tazer. a tazer, a tazer lite and a tazer mini . Whats the difference? Are the lite and the mini the same thing?
OldGuyNewJeep
Don
CT
Tazer is two pieces - a bypass module for the secure gateway and then the actual programmer that plugs into your OBDII port
Mini and lite are the same hardware - programmer is built into bypass module keeping OBDII free. Lite has some features disabled, but can be upgraded by paying for an unlock code.
I have the original two piece and like it. I can unplug it, easily. Mini seems like more work to disable on-the-fly as it requires unplugging secure gateway wires.
River City Offroad
Marcus
Dripping Springs, TX
www.RiverCityOffroad.com
2019 JLUR Triple White - RK 3.5" X-Factor Stage 1 / Steer Smarts / Mickey Thompson / Fuel
Owner at River City Offroad
Jammer
Ft worth
Bright white JL Rubicon
All I care about is changing the TPM light to not come on at 31 and change it to about 25 so I can run 28 psi in my 37 13.50 17 cooper stt pros.I am running 32 now and it's a not a bad ride but the light keeps coming on when it gets cool outside and it drops to 31 the light will come on. And i did a caulk test and its not touching the caulk on the ground on the inside and outside of the tire so its not going to wear right. So i need to drop it to about 28 psi i was told since it's a 10 ply tire. And other thing i want turned off is the start stop button. Everytime i come to a stop i hate it turning off the motor that can't be good for the starter. is everyone else happy with theirs and i did see the light show looks cool.and i wouldn't mind having the hood alarm but thats on the mini.Anyone use the hood alarm does it make the horn sound if you open the hood when its armed ?
OldGuyNewJeep
Don
CT
Jeep Wrangler JL Tazer JL vs Mini upload_2019-10-22_7-38-30
The answer to you questions is yes. TPMS, ESS and alarm work as advertised.
Fred
Orange County
Wrangler JL
After changing your tire size & TPMS can the Tazer be completely removed without loosing the new settings?
Rudolph Hart
Cheshire UK
2018 JLUR GME Mojito!
Semi retired
The Tazer has ‘vehicle settings’ (these include tire size and the TPMS threshold) which stay as you’ve set them if you remove the Tazer.... and ‘live settings’ (stuff like winch mode and turn cam) which require the Tazer to be married to the Jeep.
Jammer
Ft worth
But if you unplug the taser it doesn't automatically unmarry it does it ? I thought you actually have to go in there while it's plugged in and unmarry it while it's still plugged in
Rudolph Hart
Cheshire UK
Semi retired
Yes but I’m assuming anybody doing this will read the instructions
Jammer
Ft worth
Yes but considering they don't come with instructions and you have to go online anytime you have a question to look at the instructions maybe they might not
Rudolph Hart
Cheshire UK
Semi retired
This is a rather futile discussion. Are you suggesting that they would have been able to install and use the Tazer without access to the instructions?
Mechanick
Nick
Philadelphia
Hey guys quick question, so i am thinking of getting a JL mini for my jeep as i recently upgraded to 35s and figured its better to have this vs have the dealer flash my jeep. I have a couple questions.
1. Each time you take it into service or dealer work do you guys un marry and remove?
2. When you unmarry and then plug back in do you have to reprogram everything?
Thank you in advance for the insights!
Newbie here so much appreciated.
