Buzze
Heck ya! A discount and ships next business day, thanks! That was quicker than I expectedI’m not sure what was going on, sorry!
Thank you! Let me know if there is anything else I can ever help with!
Marcus
Marcus
Tazer is two pieces - a bypass module for the secure gateway and then the actual programmer that plugs into your OBDII portI saw 3 listings for a tazer. a tazer, a tazer lite and a tazer mini . Whats the difference? Are the lite and the mini the same thing?
Thank you! :DHeck ya! A discount and ships next business day, thanks! That was quicker than I expected![]()
All I care about is changing the TPM light to not come on at 31 and change it to about 25 so I can run 28 psi in my 37 13.50 17 cooper stt pros.I am running 32 now and it's a not a bad ride but the light keeps coming on when it gets cool outside and it drops to 31 the light will come on. And i did a caulk test and its not touching the caulk on the ground on the inside and outside of the tire so its not going to wear right. So i need to drop it to about 28 psi i was told since it's a 10 ply tire. And other thing i want turned off is the start stop button. Everytime i come to a stop i hate it turning off the motor that can't be good for the starter. is everyone else happy with theirs and i did see the light show looks cool.and i wouldn't mind having the hood alarm but thats on the mini.Anyone use the hood alarm does it make the horn sound if you open the hood when its armed ?
The Tazer has ‘vehicle settings’ (these include tire size and the TPMS threshold) which stay as you’ve set them if you remove the Tazer.... and ‘live settings’ (stuff like winch mode and turn cam) which require the Tazer to be married to the Jeep.After changing your tire size & TPMS can the Tazer be completely removed without loosing the new settings?
But if you unplug the taser it doesn't automatically unmarry it does it ? I thought you actually have to go in there while it's plugged in and unmarry it while it's still plugged inThe Tazer has ‘vehicle settings’ (these include tire size and the TPMS threshold) which stay as you’ve set them if you remove the Tazer.... and ‘live settings’ (stuff like winch mode and turn cam) which require the Tazer to be married to the Jeep.
Yes but I’m assuming anybody doing this will read the instructionsBut if you unplug the taser it doesn't automatically unmarry it does it ? I thought you actually have to go in there while it's plugged in and unmarry it while it's still plugged in
Yes but considering they don't come with instructions and you have to go online anytime you have a question to look at the instructions maybe they might notYes but I’m assuming anybody doing this will read the instructions
This is a rather futile discussion. Are you suggesting that they would have been able to install and use the Tazer without access to the instructions?Yes but considering they don't come with instructions and you have to go online anytime you have a question to look at the instructions maybe they might not
