Taser HELP
Alf1096
Kody
JLUR
Long story but want to put all the information in there so I can get the best help. A month ago I put a remote start x and a new battery on my jeep due to the battery dying. At the same time I did the aux battery bypass and pulled the fuse. I used the jeep this way for approximately 2 weeks to make sure no error codes showed up. All worked as it should. So to keep from having to hit the start stop button every time I bought a taser mini. Updated it and put it in the jeep. When I first plugged it in the tazer had no lights. But a key cycle or two and opening the door and it lit up. I was able to marry it without issue. Approx 2-3 weeks go by and everything is good. I drove my jeep last Wednesday and when I went to drive it Friday it had a dead battery. The battery wouldn’t take a charge so I got a replacement. Now I cannot access my tazer and it will not light up. I got it to work one time and was able to unmarry it.
Now my taser will not update. To get my computer to see it I have to wait 5 minutes of it not being plugged in and it will show up. If I unplug it and plug it right back in it will not recognize it. If I plug it back into my jeep I get no lights. I am however able to get the tazer up on my laptop and then plug it into the jeep and the jeep will see it but when I try to marry it I get BCM 18 busy and it will not marry. I have searched for answers and reached out to tazer but its Saturday so I am looking for some help. Any suggestions.
Grayhound
Michigan
Jlurd
did you try recovery when you plug your tazer into your computer?
Alf1096
Kody
JLUR
I did I get to the part where it says unplug it and plug it back in then I get nothing.
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
