Tapping into tow wiring
Yorkie3621
stephen
charlotte
2018 Jeep JLU Sport S. Silver/Tan
I just bought the Form sequential tail lights.
These lights have a tap into the turn signals, but rather than run wiring from rear to front, can’t I just tap into the factory tow wiring instead??
If so, anyone know what colors are for left and right indicators?
Thanks a lot
Terrymo
Terry
2023 JLURXR 3.6 ET
This is universal wiring colors. You can test at the connnector with a multimeter or test light to verify
Jeep Wrangler JL Tapping into tow wiring IMG_1157
Terrymo
Terry
2023 JLURXR 3.6 ET
Thanks a lot
You might try installing an inline 7 pin t harness adapter and tap into that rather than risk damaging your factory wiring only to find out it wont work.
Maybe try a jumper wire from the 7 pin connector to the sequential wire before tapping into any wires.
Just brainstorming and making wild ass guesses.
Gregj
Greg
West Texas
I wired some reverse lights into the plug on mine and it does work. Just keep in mind on initial startup the trailer harness is not immediately powered, it takes a couple seconds for it to cycle through and come on. After it is running all is good. X2 on getting a 7 pin t harness so you don’t cut into the factory wires.
Gregj
Grayhound
Michigan
Jlurd
Gregj
Is that why my oracle reverse lights that I tapped into the trailer lights don’t come on with the reverse light from key fob sequence?
Gregj
Greg
West Texas
Yes, the trailer harness isn’t “on” until the Jeep goes through the startup self test.
Gregj
Yorkie3621
Yorkie3621
stephen
charlotte
Thanks a lot, guys. That really helped me out
MacombRoger
Roger
SE Michigan
2018 JLUR Ocean Blue
Solution Architect
Wow searching this morning and so happy to find a recent thread. Anyone know of a t-harness 7 pin for the Jeep? I swear I remember a Jeep JL specific one a while back, but cannot really find it today. I am going to be adding "whip lights" for parades, etc. and they can do blinker/brake/reverse lights too, and though tapping the 7 pin is the way to go.
Thanks for the help!
Gregj
Greg
West Texas
Amazon has some pretty good deals on them.
https://www.amazon.com/gp/aw/d/B0009FJ38Q/ref=ox_sc_saved_image_1?smid=ATVPDKIKX0DER&psc=1
Gregj
Armendegga
Morgan
Valdosta, GA
2018 Jeep Wrangler Unlimited Rubicon
How much power will it allow you to draw? Thinking about doing this to add a couple lights to use as reverse lights since the led one in the brake housing is terrible. Maybe some KC C20’s?
MaybeRubi
Wyoming USA
'24 JLU Willys 3.6 Auto Anvil
I believe this is a related question:
Here is an adapter from Viair that can be used to power some of their compressors from the seven-pin trailer hitch connector. Viair says "Be sure to check your auxiliary power circuit rating to make sure it supports the max amp draw of the compressor you're using." Does somebody know the "power circuit rating" of the factory JL plug? (It does seem a cleaner way to go than using the battery terminal clamps.)
Thanks.
Gregj
Greg
West Texas
Fuse f111 is for the trailer backup lights and is a 20 amp fuse so use that as a guide as to what you can hook to that circuit.
Gregj
