Tail Gate hinges not sealed?
TIDALWAVE
CHUCK
MINNESOTA
2015 Mustang GT Convertible, 2013 CHEVY SILVERADO, 2018 JLUR
I was thinking about replacing the hinges on my tailgate, part of a replacement of the tailgate tire bracket. Inspection shows that the hinges extend into the body and an open gap around the hinges as they penetrate the body. If this correct? Or did Toledo forget to use sealant?
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
Pictures would help
TIDALWAVE
CHUCK
MINNESOTA
Just look at your hinges...is there sealant around where the hinge brackets extend into the body panels? Mine are not sealed. Just wondering if that is normal or Jeep forgot to seal mine.
TIDALWAVE
CHUCK
MINNESOTA
I live where they put lots of salt on the roads during the winter. The unsealed hinges will be a great place for salt water to enter and start corrosion.
At first. I looked at the hinges with the tail gate closed. I thought a simple bead of sealant would close of the gap. But I then opened the tailgate. You can just about put a couple of small fingers in the gaps around the hinges. The gaps are about 1/2 inch wide by 2+ inches long.
Driving where there is a lot of dust or fine sand, you are eventually going to have a lot of material collecting inside the panel spaces near the hinges! I have never seen a vehicle before that has such large open gaps on the side(s) before!
I am going to make some vinyl gaskets that are going to be 'glued' onto the gaps to cover them up.
If you don't believe me...open your tailgate and look at the gap where the hinge pieces enter through the sheet metal!
