Swapping Halogen Tail lights for used OEM tail lights without Mounting Bracket.
BW1910
Bill
New Jersey
2022 Jeep Wrangler
Hi,
I found a pair of used OEM JL tail lights for under $350 on eBay. They do not come with the mounting bracket. If I take out my halogen lights and use the existing mounting bracket, will they be plug and play or will I have to use a tazer to avoid problems.
Thanks
lashlee
Knoxville, TN
'18 JLUR 2.0 Turbo 4 (Sold), Tesla M3P
I think they should work. I can't remember if I had to swap brackets when I did it to my wife's JLUR.
jludave
The Isle of Long
IT Manager
Hi,
Thanks
The mounting bracket should swap right over.
As I recall, going from OEM halogen to OEM LED taillights requires using a Tazer or JSCAN to set the vehicle to LED.
Dan M.
Albany NY
2020 sport (2 door)
I've seen some say no reflash is neccessary, and others say it is. Seems random.
zrickety
Technician
I think if they are aftermarket lights, you don't need to. Factory LEDS probably need the correct setting.
jludave
The Isle of Long
IT Manager
It's not random. Factory/OEM LEDs typically need a flash.
Aftermarket headlights and taillights are meant to replace halogens and typically don't need a flash.
Chrismeece74
New Port Richey, FL
2021 Wrangler Freedom Unlimited
You do not need a reflash. Reuse the brackets off the halogen tail lights and put them on the OEM LED tail lights. We did this exact swap on my Wife's 21 JLU and they are plug and play. No issues at all.
