Suspension sag, just one corner?
Chaostactics
Hawaii
JLU
I shoulda measured all 4 corners before adding the lift but didn't, so I'm not sure if it's lift related or not. (Put JLUR shocks+springs into a JLU Sport S and added 0.75" daystar spacers all 4 corners for ride quality/height).
Both drivers side corners and rear passenger have a height that is almost exactly 39" to center of lower part fender to the ground. The passenger front however is 38".
Is 1" off normal or did something go wrong with the lift?
4xFUN
Scottsdale AZ
2024 2-door Ruby-X, 2020 2-door Ruby, 2023 RAM TRX
Did you put the 'taller' front spring on the driver side? The taller/longer springs should go to the passenger side. If you have the vin of the Rubi they came off of, you can use it to pull the part numbers for the springs and then match them up with the tags on your springs.
Chaostactics
Hawaii
JLU
Fortunately but unfortunately no we double triple checked we were putting the taller ones on the passenger side.
4xFUN
Scottsdale AZ
That sucks. Did you use OEM spring perches or aftermarket? If OEM, also the taller perch goes on the passenger side.
Chaostactics
Hawaii
JLU
I kept the OEM ones and added Daystar spacers. Each perch went back to the spring placement it came off off.
