Superchips Flashcal for JL is here!
pete_s
Pete
Boston
2018 JL Unlimited S
What about the ability to turn off the Engine Start/Stop function?
Mike@Powerteq
Summit Sponsor (Level 3)
Sanford FL
www.superchips.com
16 JK, 18 JL 2.0T, 22 Wagoneer 3.0TT
Senior Category Manager – Domestic Tuning at Holley
That requires that you stay plugged into the vehicle.
Since our TrailCal device stays connected as a monitor, we are looking to add that feature to that device for sure.
As for adding it to the current Flashpaq, I'm not sure at this time.
Thanks
JASPER
Wayolife Sucks
Tucson
2018 JLU Rubicon and 2014 JK 2dr
NEED TUNER!!!!!!!!!!!!!!!!!! 2HI DISCONNECT FEATURE !!!!!!!!!!!
Texas_Yote
Kris
Prosper
www.instagram.com
18 JLUR Granite, 15 JKS 2DR, F80 M3
Slang 1's & 0's
Will adjusting for 35's adjust the shift points as well with this programmer? On long road trips it seems to bounce around in 6-7-8 much more than 33's. I know rehearing would be best but I am hopeful this could put a bit of a bandaid on it for now.
Mike@Powerteq
Sanford FL
www.superchips.com
Yes, correcting the speedo should clean that up.
Thanks
Texas_Yote
Kris
Prosper
www.instagram.com
Slang 1's & 0's
Thanks
In stock, any forum discounts? I'll order now if so :)
Later on, if tunes come out form you, can I purchase them and upload them using this device?
**Edit- Thanks for the fast reply!!!!!
Superchips JL
Superchips JL
Jeep Team @ SC
Sanford, FL
2018 JL Rubicon
Yes sir on the update - you should be able to add tuning once we have that available. Something that certainly distinguishes our product as a handheld option.
You may look around here on the forums as we do have re-sellers that look to offer some options to JL members. Thank you!
MotoMax
Bob
S. Hatteras Island
2018 JLU Rubicon, 2020 Jeep Grandcherokee
Do nothing bum Retired
Locker options are still being investigated.
Thanks
I to would love to have a 4H engagement option for at least the rear locker. We do a lot of driving in sand.
Just today I received my new programmer. Used it to correct the speedometer for the larger tires and lower the TPS low pressure warning threshold. Worked great. Using the lockers in high range is the only added feature that I would love have on the Superchips programmer.
WXman
Central Kentucky
2018 Wrangler Unlimited
Why no option to adjust TPMS threshold? Many of us want TPMS, but don't need to keep our tires at 36 PSI.
MotoMax
Bob
S. Hatteras Island
You can adjust the TPM threshold limits with the Flashcal. They really should have that on their features list. Probably missing some sales.
The only off roading I do is on sand so a lower air pressure makes driving less effortless. Set my TPM's to set a warning at 24lbs. ILO the factory 30lbs. on the Rubicon and it works well.
Swanny297
NELA
2018 JL
Happy with the flashcal, all features work on my sport, the only thing I haven’t tried yet is the data logging feature. Disabling autopark did work on my sport as well.
Superchips JL
Superchips JL
Jeep Team @ SC
Sanford, FL
2018 JL Rubicon
TPMS adjust is active however we were conducting some final testing before we touted the feature. Stay tuned for Flashcal 2.0 updates. Some exciting stuff included!
boogie
kelly
jeep jl
Can you turn off the feature that blocks the brakes when your doors open and you put it the jeep and drive?
lookitsadam
Tampa, Florida
2018 JLU Sport
After using the Flashcal to recalibrate for tire size do I leave the bypass module plugged in or can I remove it? The instruction book provided with the Flashcal is great at explaining the options included but not so much at showing overall steps.
Swanny297
NELA
2018 JL
I left my by-pass module connected but in discussion with Superchips you can remove it after you have programmed.
