[email protected]
Summit Sponsor (Level 3)
Sanford FL
www.diablosport.com
2020 Mustang GT, 18 JL shop vehicle
DiabloSport Brand Manager at Holley
Superchips is pleased to announce our all new, mobile Flashcal+ device. This app based options device offers all the control you are after on your JK, JL or JT. With innovative new features like the Tire Size Wizard and standards like TPMS adjustment, it offers something for everyone. Devices are in stock and available now. Click the link to learn more!
https://superchips.com/flashcal-flashcal-plus-jeep-newest-device-wireless/
JK Features:
  • Corrects speedometer for tire upgrades between 26”- 42”, using GPS-powered Tire Size Wizard or by measured height
  • Speedometer recalibration for axle gear and T-case ratio, 2.73-5.38:1
  • Axle Lock Rear w/ T-case in 4-Hi & 4-Low (CRAWL Screen, JK Rubicon only)
  • Axle Lock Front & Rear w/ T-case in 4-Hi & 4-Low (CRAWL Screen, 3.8L JK Rubicon only)
  • Engine idle up for winching, temporarily with CRAWL Screen, 500-2000 RPM
  • Daytime Running Light Location: Halo, Fender, Fog, High, Low, Turn Signal
  • Daytime running light Enable/Disable
  • One touch lane change
  • TPMS Disable, while using CRAWL Screen or completely for use with aftermarket wheels
  • TPMS Threshold adjust 22-56 psi.
JL/JT Features:
  • Sway Bar Disconnect in 2Hi, up to 25 MPH (CRAWL Screen, Rubicon only)
  • Line Lock- holds brakes on front tires only
  • Rock Lock- holds all 4 wheels with brakes for crawling
  • Axle Gear Calibration: 2.73 – 5.38:1
  • Tire Size Calibration by height: 26” – 40”
  • Transfer Case Gear ratio calibration: 2.72 – 5.00:1
  • TPMS Warning Threshold adjust: 22–56 psi.
  • TPMS Disable, for aftermarket wheels and no sensors
  • TPMS Off/On (Crawl Screen)
  • Daytime Running Lights Operation: Always On, Selectable, or No DRL
  • DRL Location Selector: Fog, Fender, Running, High, Low, Turn, or No DRL
  • DRL Dropout Disable, keeps DRL on when using turn signal
  • Fog Lights Dropout Disable, for simultaneous use of high beams and fog lights
  • Halo Lights Enable or Disable
  • One Touch Lane Change Enable
  • Dashboard Splash Screen select: Rubicon, Sahara, Sport
  • Seat Belt Minder Disable, stops chime
  • Travel Link Weather Warning Disable
  • Lighting Config, selects Standard or LED: Front Turn, Tail Lights, 3rd Brake Light
  • Auto Start/Stop Disable
  • Auxiliary Switches Enable, to add extra factory Aux switches*
  • Blind Spot Detection Disable, or Enable to add if not equipped*
  • Factory Fog Light Switch Enable, adds controls if not equipped*
  • Towing Package Enable, adds controls if not originally equipped*
  • Backup Camera Disable, or Enable adds if not originally equipped (2018-2020 JL Only) *
  • Cargo Camera Disable or Enable adds if not originally equipped (2018-2020 JL Only) *
  • Electronic Steering Pump Disable, for conversion to hydraulic system*
  • Axle Lockers Disable Rear Only, OR Front and Rear for conversion to manual*
  • Axle Lock Rear OR Front and Rear w/ T-case in 4-Hi & 4-Low (CRAWL Screen, Rubicon Only)
    *Our devices reconfigure vehicle controls for this associated change, but additional OEM or aftermarket parts are required to complete the conversion.
cavguy
Los Angeles
2020 JLUR
Will Superchips continue to support the older model Flashcal for JL with software updates? Or is this new model intended to gradually phase out the older one (likely meaning that software updates for the old model will stop in the near future)
[email protected]
Sanford FL
www.diablosport.com
Yes, we will continue to support them. We are still offering that device along with the mobile version. This is just a new option.
rkeen81
2019 JLU Rubicon/2023 JLU Rubicon 4xe (Hydro Blue
What limitations are there for the 4xe?
[email protected]
Sanford FL
www.diablosport.com
For those that are curious about the Mobile Flashcal+, SUPERCHIPS offering.....
You can go to Google Play Store and search FLASHCAL+ and download and the install the Flashcal+ app on your Android smartphone....... and then.... then you can go through/select DEMO MODE in the app and fool with the app all you want/ get a feel for it's use...
Yes! Thanks for sharing that, same option exists for iPhone users!
Steph1
Steph
Quebec, Canada
Jeep JLU Sahara, Audi Q5, Porsche 911
If I didnt already have the Jscan, I’d probably go with this new flashcal, as I’ve really gotten used to making the adjustments with my cellphone.
Wheelin Matt
Allenspark, C/ Palm Springs, CA
2021 JLUR Xtreme Recon
Mike, I have a late 2021 JLUR XR with the 3.6 (so with updated software from the earlier models). I have not used any device like this before but I have 37’s and some of the features mentioned in your post above sound very appealing to me since I rock crawl and wheel quite a bit.
I noticed there were a couple different items when I went to your website so I just want to be sure I purchase the correct device for my Jeep so I can have the above listed attributes (sway bar disconnect up to 25, Line lock, Rock lock, tire size calibration, etc).
Can you post a link to the exact device/app for my Jeep that I can use my iPhone for these features?
THANKS!!
Picture of my Jeep in its favorite environment
[email protected]
Sanford FL
www.diablosport.com
THANKS!!
Here you go!
https://superchips.com/shop/flashcal-for-jeep-wrangler-jl
Retrograde
Michael
God's Country, Idaho
2020 JLSS, 1995 Chevy K2500
Arms Dealer
This jumps out at me...
...because goddam, I HATE electronic steering. Someone please point me to a company that offers the conversion kit!
sstuner
Ray
Northern Virginia
2018 Jeep JL Sahara
May have missed it, can the rear camera "turn on" with turn signal and/or turn on manually and stay on?
J0E
J0e
Hawaii, MT, SLC, NYC
bt39.com
2021 JLR, 2023 JLUR ordered
Is there an updated comparison to Tazer? I use winch mode frequently and don't want to connect a device just to enable it. cc @[email protected]
Cypher
J
AZ
Cybersecurity Leader
JK Features:
JL/JT Features:
Does this really not support the Eco-diesel, or is that just a glitch on the Website? When I enter in my Jeep info these are not listed as supported.
TopLift Pros
