Stuck in Park & Won't Start
Rustynail11
Mansfield, TX
2022 Wrangler JLU Rubicon
Can't get my rig (2022 JLUR) out of park or started. Thought battery so jumped it and no luck. Did Aux battery bypass by pulling F42 and the negative cable and no luck. Electronically the Jeep is acting normal. All gauges, window, radio, locks, lights etc. work as they should it just won't start.
Any ideas before I have it towed to a shop or dealer
Lumpello
Minnesota
2021 Sahara
If you don’t have to get it moved immediately (off a street for example) My first thought is to pull the battery and charge it fully. I brought mine to O’Riley to get tested to see if it was bad, they fully charged it before testing it.
My wife’s had a similar issue ‘21 Sahara Altitude 3.6- died while she was driving, put it in park & turned off. We were able to get power to come on but it said to put it in park and wouldn’t start or even try to crank. It was in Park and I could not shift to neutral.
Charged for a bit off of another vehicle. From what I remember I had to get it into accessory mode and turn it back off. Somehow it recognized that it was indeed in park and cranked right over. Got it started and moved out of the way. Pulled the battery to get it checked- parts store charged it since it was low. Tested it, said it was fine. Put it in and ran fine.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Doesn't even try to start? I think there's a run relay/accident shutoff.
