Strange noise
got the willys
2020 jl willys
I have a 2020 willys. About year ago I noticed around 30 to 40 mph if i accelerate going up incline there is noise sounds like marbles rolling around in tin can. Stops after 40mph. Wont do it just revving engine. Anyone experience this and find a cause
Sparty
SW Michigan
04 TJ, 21 JTR, 21 JLR
A complete guess.....but, it sounds like you have the 4cyl turbo
kah.mun.rah
Merenkahre Jr.
Duat
Do you by chance have a wheel lock and empty beer cans in your center console?
Pape
Quebec
JLU Sahara
Marble in tin can sound like a cat converter that is in the process of breaking up
Take a rubber hammer and hit the cat and see if you got some loose stuff in there
got the willys
2020 jl willys
I have the 6cyl. Funny on beer cans. I was expecting to hear I lost my marbles. Ill ck on cat converter but it only has 36000 mies so cant imagine would be that
jadmt
jeff
montana
that is detonation....classic. won't do it it revving under no load but under load sounds like marbles in a tin can or tin foil being crumpled up. try higher octain
got the willys
2020 jl willys
Tried that. Ive read others have had same issue. Whats odd is it seems to come from rear. Its not like enging ping or knock
q2bruiser2
2025 Jeep Wrangler Rubicon X
Sound is funny when in a moving vehicle. I had a Hellcat that I just knew had a rear end bearing or similar going out. Turned out to be the front bearing on the supercharger. I'd try running a few tanks of premium fuel.
