Steering Wheel Heater?
NJ_JL 2020
NJ
2020 Wrangler JL Unlimited S
All, 2020 JL with 44K miles. Steering wheel heater quit. Light stays on for 2 seconds and then shuts off. Any way to fix this on my own? Thanks.
jludave
The Isle of Long
IT Manager
Check/test fuse F60.
Cutterone
NH
2025 Willys 4dr 2L Firecracker
Common problem, mine is out as well, its been out for a year. Dealer ordered the part it needs I guess, but got too busy and haven't gone back to dealer to install part, I guess I should do that. This defect occurred before the end of my 36k full warranty, but I foolishly didn't go back to have the work completed. If I do, since the dealer has on file the defect they should repair it under warranty even though I am now out or warranty...yeah???
NJ_JL 2020
NJ
Thanks. Do you know what parts are required for your fix?
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
If it's the element in the wheel, the swap won't be bad, but you'd replace the wheel, which is $$$$.
jludave
The Isle of Long
IT Manager
Only one who can answer that is your dealership.
Impy5
CT
2020 Wrangler Unlimited Willys
I had this problem earlier this winter, dealer said the clock spring needed to be replaced. Replaced it and it has been working fine since.
