Steering Stabilizer Replacement
dajuicejml
Justin
North Carolina
2024 JLRU 392
This thread is a little dated, but has anyone confirmed fitments on the fox Stabilizer
Fox® Racing Shox 983-02-148 Factory Race Series 2.0 ATS Steering Stabilizer for 18-22 Jeep Wrangler JL & Gladiator JT
Curcurt
Curtis
Hammond, LA
2021 Jeep Wrangler Rubicon
Yes, easy job. I relocated it with Synergy relocation parts.
You will need the following parts from Synergy:
4050-63 Rod clamp for a factory JL tie rod
8806-01 Stabilizer mount stud
4051-01 Clamp adapter for Fox TS and ATS
I did it a few months back and getting the parts was a little hard. Might be better now.
cgrosen324
Las Vegas, NV
2020 Ford Raptor
Has anyone installed a steering stabilizer on STOCK 392? I bought the Fox Series 2.0 ATS Steering Stabilizer (# 983-02-148), which is supposed to be a direct bolt-on. I'm not having any luck because it appears the replacement bracket does not provide proper alignment. Wonder if anyone else has experienced this?
Note: There was a mid-2021 change by Jeep on the bolt that mounts the stabilizer to the tie rod (closest to the wheel). You actually have to order the 2018-2020 Mopar bolt for mounting an aftermarket stabilizer to the factory mount . . . Mopar Part # 6510774AA. See video.
I attempted to install the Fox ATS a couple months ago and can confirm…the bracket does not line up with the 3 bolt holes on the axle. In fact, like a dummy, I attempted to force it and ended up miss-threading one of the bolts. I had to re-thread and go with a slightly larger bolt. I’m an idiot. Anyway, I ended up installing the adjustable Falcon stabilizer and I’m pretty happy with it.
santa
Alex
Phoenix AZ
'21 392Rubicon
Again dated but let me share my experience anyway.
I did install this kit to my '21 392 but had no issue with the FOX bracket. I guess it is just a part accuracy issue?
Of course I needed to buy the old Mopar bolt originally mentioned in this thread.
Jeep Wrangler JL Steering Stabilizer Replacement IMG_1786
Jeep Wrangler JL Steering Stabilizer Replacement Image 11
Jeep Wrangler JL Steering Stabilizer Replacement IMG_1785
