My JL has gone wonky over the last 3 weeks. Everything was fine and then bam, my needle speedometer is all over the place from 1mph high to 10mph high.
Every time I start driving, turn off the engine, get out and do my errands, and then restart it, it will climb 1 mph, every cycle.
It then randomly resets and starts all over again. I cannot trust it, and always have to use the digital readout.
Also when the speedometer is acting up it will read that I am traveling anywhere between 1-10 mph while in park.
My JL Rubicon was built at the end of March, delivered April 15, and purchased the 16th by me. I had 800 miles on it when it started and now have about 1050 miles on it today.
I am also experiencing the loose steering, but I think I have one of the worst cases. My wife wont touch the Jeep as she is scared of the steering, and she drives a huge vehicle (2017 Expedition) just fine. My steering is so bad that one of my cop friends told me he would have pulled me over as he thought i was drunk ans swaying within the lane.
My wheel is still clocked at 1130 even after an alignment.
I love it as it is a pretty nice vehicle, but these issues are making it pretty hard to live with.
The speedometer inaccuracies is a warranty issue.My JL has gone wonky over the last 3 weeks. Everything was fine and then bam, my needle speedometer is all over the place from 1mph high to 10mph high.
Hi wb880,My JL has gone wonky over the last 3 weeks. Everything was fine and then bam, my needle speedometer is all over the place from 1mph high to 10mph high.
On the JL it's just one bolt. 15mm . Turn it only a LITTLE bit and check it. DAMHIKT !!Adjust the sleeve on your DRAGLINK to center the steering wheel--
Two bolts, they were 15mm on my '08 JKUR, but you should have a full set of metric sockets anyway
Good luck
JIMBO
Today I noticed that my electronic Speedo is way off. SHowed that I was going 90mph when I was really travelling 60.Took it in, they called FCA did something to the computer flash or reboot and its all good now.
Only other issue is a biazzare clicking noise when your turning seems to be coming from the front end somewhere...
Not sure if you noticed, but your digital reading is in kilometers per hour.Today I noticed that my electronic Speedo is way off. SHowed that I was going 90mph when I was really travelling 60.
I took the below photo at a slower speed. My actual speed was ~25mph which matches the analog. WIll be making an appointment to take it in.... only 426miles on the odo.
DOH! My daughter is gonna get it! This is today's dose of humility. Thank you for being eagle-eyed!Not sure if you noticed, but your digital reading is in kilometers per hour.
Ah man, I totally thought the pic was a joke. Classic.DOH! My daughter is gonna get it! This is today's dose of humility. Thank you for being eagle-eyed!
It could be your goggles!DOH! My daughter is gonna get it! This is today's dose of humility. Thank you for being eagle-eyed!
