Soft Top Mishap
j-rob
South Carolina
Incoming 2023
So I recently purchased a used mopar soft top. While assembling it one thing led to another and the passenger side rear lifting mechanism is toast. It needs to be replaced and I think this is the part:​
My question is if any of you know how I go about installing this and reattaching the release mechanism cable?​
Any help would be greatly appreciated.​
thecritter
Rusty
East Texas
2018 Crystal Granite JlU Rubicon
Those can be a pain if never done it. Some velcro or straps help a lot. Top in folded back position tie it up some way. As for part replacement is it just bent? I accidently bent mine once and was able to straighten it out.​
Ormond Beach, Florida
Retired at 55 ..
@j-rob
https://www.jlwranglerforums.com/forum/threads/replacing-bent-bow-arm-on-soft-top.51980/
j-rob
South Carolina
Incoming 2023
Unfortunately mine is all in the mechanism. The rods aren’t bent.
j-rob
South Carolina
Incoming 2023
I'm guessing that this isn't a common replacement haha
JP29
Zach
Olathe
2020 JL Sport
Disassembly of that was part of my soft top fabric swap last year. I remember that area being a little tricky, just because the metal was all sandwiched together in such a way. But it's pretty straightforward, take pictures before you take it apart and mirror that when putting it back together. I think it's no more than four bolts.
j-rob
South Carolina
Incoming 2023
Thanks so much, any tips or pics of your swap?
JP29
Zach
Olathe
2020 JL Sport
Sorry, I got through typing all that and thought, "...should've just linked my thread!" :facepalm: Here you go , and if you have any other issues on it ping me and I can take better pictures of how it comes apart later tonight if needed.
Danu924a
Long Island
22 Sport
yes that’s the part. I had same issues. Im
Having trouble with removing the tension cable. Has anyone had any issues with that ?
Jeep Wrangler JL Soft Top Mishap 65270FDC-CA94-4950-B269-8C0F012C3B05
JP29
Zach
Olathe
2020 JL Sport
My guess is that part isn't meant to be end user serviceable. I never worked from that end when I swapped the skin on my top - the soft top frame has been on mine since install in Toledo three years ago. Could try to pop it out with a plastic pry tool maybe?
Disclaimer: @JP29 assumes no liability for performing any of the steps that may have been suggested. Perform all disassembly at user's own risk. May contain peanuts.
Danu924a
Long Island
22 Sport
ya. I was prying it gently and had no luck. I ended up taking the old broken mechanism apart and was able to pinch it with pliers from the inside. There was a lot of tension in the frozen light arm mechanism so it blew apart like a bomb. If anyone tries these please wear safety glasses and maybe put a cloth over the mechanism when u pop it apart.
Danu924a
Long Island
22 Sport
Sorry about typos. ‘Lift arm’
