TrailScooter
Make sure nothing crawled under the hood and died. That’ll smell.
I found a bunch of goo from dead dinosaurs. Flushed it all out and replaced it with spring water.
This stuff works great when you spray directly on the cabin air filter.
remove the filter and spray inside that area?This stuff works great when you spray directly on the cabin air filter.
Yes and filter but light on the filter.remove the filter and spray inside that area?
I took my 21 JLUR with 15 K miles to two Jeep dealerships and both refused to address the issue under warranty. I had an airborne mold test done in the Jeep (doors on and windows up and running AC on max and recirculate for 30 minutes with four “gravity trays” placed throughout the car, then leaving the trays in the Jeep for an additional 30 minutes with the engine/AC off) and the results were shocking and definitely explained my asthma attacks white driving with AC on (before I figured out what was causing them). BUT two dealerships refused service under warrantyTo be clear, I was describing the work that should be done by a qualified technician.
This will never, ever reach the areas that need to be cleaned. This is air freshener.
