Small clunk on transmission when engaging
Goheels050917
Dustin
Raleigh - Durham, NC
2018 Jeep Wrangler JLU (SOLD - March 2021)
SD-WAN Engineer - Technical Author
Every once in a while when I either go into drive or reverse, I'll hear a clunk. Sometimes its loud, and sometimes nothing.
Does you wrangler do the same thing?
brewtus98
Bryan
Toledo, Ohio
2018 Sahara, 2003 TJ, 2004 TJ Rubicon, 2004 LJ
I get a clunk if I am parked on incline and the engine is a fast idle during this cold weather when shifting from Park into Drive or Reverse. Give it a few minutes to let the idle come down a little and no issues. Been doing it since it got cold out - last 3000 miles or so.
Sean L
Sean
North Carolina
I believe this clunk is the drive-train components tensing up after sitting idle with no torque application. I use my parking brake so that might have to do with it as well. It was the same in my Ram 1500.
timn1984
Tim
Louisville, KY
Jeep Wrangler Unlimited 2018 JL Sahara,Dodge Journey 2012, Toyota Camry 2015
Yes
I get the same "CLunk" when shifting from P to R or D. SO if I just wait for a few seconds after starting engine will it still happen?
Sean L
Sean
North Carolina
You'll still have slack in the drivetrain, so you'll still get it. It won't be as dramatic at 800 RPMs instead of 1100 though.
timn1984
Tim
Louisville, KY
Yes
Is it a problem, I mean should I go to dealer and check it out? Or is this relatively normal?
Sean L
Sean
North Carolina
It seems normal to me, it was the same in my Ram 1500, and that was the only other auto I've owned. Didn't notice it in my manuals.
AbeWay
Abe
Wyoming
2018 Jeep Wrangler Sport S
Take that into the dealer so they have a record of it. They're going to tell you nothing it wrong but traditionally when I've seen it the torque converter goes out after a while. Make sure to go back a few times again and they write up paperwork on it.
Goheels050917
Goheels050917
Dustin
I guess Ill change my license plate to 'clunk'.....it will be a good conversation starter I guess.
Maverick909
I.E.
most cars do this. more noticeable when parked on an incline of decline and the drive fails to use the parking break that was intended to keep the vehicles weight off the drive line and keep it in one place. i get a bad clunk in my 76 gmc when i dont use the parking break. then again that is 40 plus years old. try making sure the PB is engaged fully before letting your foot of the brake while in park. this should help alot
