Slight play in brake pedal
Amciano
Anna
Rhode Island
2024 wrangler sahara
B4 I spend time going to dealer for this i noticed in my new 24 sahara slight play in brake pedal I can actually lift it up with my hand a bit is this normal.?.depressing it a bit of play doesn't feel solid.. any ideas? Normal or should I get it checked?
jadmt
jeff
montana
a little play is normal
yokramer
Snark Incarnate
Amciano
Amciano
Anna
Rhode Island
Thanks for clarifying save trip to dealer
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
If you think you have a soft or mushy pedal you may need to do a ABS brake bleed.
My new Willys had a hard firm brake pedal put at 15k my brakes when soft.
I took it to the dealer and was told it is normal. As I walked out I said it is not normal and will fix it myself.
This is where I found the solution and I fixed it.
Amciano
Amciano
Anna
Rhode Island
Don't this it's this im good
