Should I be rubbing.
FireAnt21
Tony
Wisconsin
2020 Sahara Unlimited North Edition
Lineman
2020 JLU worn 2 in mopar lift 35 autturo 20 inch wheels 4.75 19mm. If I do uturns I hear it rubbing. What I’m rubbing on I don’t know and I don’t see anything I’m rubbing on
Whaler27
Alex
Oregon
Saving the world :-)
Yikes! Thought this thread was about something else! :blush:
Yep, wrong wheels.
35s work great on the factory wheels and many others, but offset/backspacing matters
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
Backspacing is good, but that offset is what's making it rub.
FireAnt21
FireAnt21
Tony
Wisconsin
Lineman
Whaler27
Alex
Oregon
To correct it? Swap wheels. Or better yet, if you’re going to use your Jeep off-road, swap wheels and tires for 35s on 17’s or 18s, you’ll appreciate that extra sidewall for the ride and performance, especially when you air down. They’ll look better too. :like:
… I know, I know, looks are a subjective thing.
GrayWolf.Overland
Subash
Maple Ridge, BC, Canada
www.instagram.com
2025 JLU Rubicon (Anvil Gray)
19 offset is plenty pushed out.. AEV wheels have +25 offset and run 35s fine. I bet the mopar lift rendered a lot of lift height and the axles are not centred now.
OP, are you rubbing only on one side - that would mean axle is offset by about an inch. if rubbing on both sides, then check clearance on lower control arms and fender air dams
Megawatt
Sin City aka Vegas
money pits: Turbo Busa, Street Bob, 22JLUR snazz, 5.0 mustang MT
Powerplant operator
If you’re rubbing the evidence is there. No way to hide it. Just gotta get dirty and get a good look.
  • Like
Reactions: OBD
kah.mun.rah
Merenkahre Jr.
Duat
Drive through some mud, let it dry, and then the rub spots will be more obvious.
FireAnt21
FireAnt21
Tony
Wisconsin
Lineman
I’m thinking with the lift and not having the axle centered was the issue. I have since installed an adjustable track bar and it seems normal so far in my turns. I’ll try some more u turns and report back.
Discount Tire
Arizona, USA
discountti.re
All Things JEEP
Tire & Wheel Specialists
Good to hear, sounds like the issue was resolved!
Curious though, how wide are the wheels and is the offset -19mm or +19mm?
You had mentioned 4.75. If this is the backspace?
FireAnt21
FireAnt21
Tony
Wisconsin
Lineman
Discount Tire
Arizona, USA
discountti.re
All Things JEEP
Thank you for the confirmation, that makes sense with the wheels being 10-inches wide.
