What tire pressure should I be at?
Shawn_1121
Shawn
New Hampshire
2020 JLU Sahara
Hey guys, sorry in advance of this a dumb question,
im running a 285/75/17 tire on a 17x9 rim what tire pressure should I be at ?
jeepoch
Jay
Longmont, CO
2019 JL Wrangler Sport S 3.6L Auto 2 door, 2.5" lift, 35s
Shawn,
If these are stock, the placard label on the edge of your drivers side door frame indicates recommended cold temperature pressure. If not, it's whatever is most comfortable to you within your tire manufacturer's specs.
Jay
Jeep Wrangler JL What tire pressure should I be at? IMG_20191130_091537
Dkretden
Denver, CO
2020 JLUR 3.6L
You will find a large range of opinions here and it also depends on what you are doing.
running down the paved road?
running off-road?
two very different pressures.
assuming paved road ....... I run (Cold) 35/36/37-ish on my 285’s — stock KO2’s. I don’t sweat a one pound difference.
Some others here seem to run lower pressures. Try it out and see what you like.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Questions are rarely dumb, but answers on the other hand...
I ran my factory 285/70-17 ko2's at 33-34 on a 4 door Rubicon.
The best course of action, to really dial it in to your specific vehicle weight and maximize ride comfort and tire longevity, is a chalk test.
sourdough
left coast
JL
yet another way many say, get a length of 1"x1" made of anything solid (iron bar stock ,wood, metal plastic)at least 12" long. With your rig normally loaded, park a tire on it so you see air space on either side of the 1x1. Air up if you don't, air down until the air space is gone. That's you air pressure for that tire, repeat for each tire.
Kluk Ztopolovky
Kluk
Toronto
Wrangler JL Sport 2dr Sting Gray manual
I run stock GY and the front is about 32 -33 and the back is about 35 - 36
