Shock replacement
MorrieC
Morrie
Kennewick, WA
Mercedes GLC AMG 43
My Jeep is a 2019 2 door Sport and I'm going to change the shocks on. The Jeep has 98,000 miles with the OEM shock, so it is time to change them out.
I'm running Rubicon take offs wheels and tires which were a great upgrade over the stock wheels and tires. So the real quetion is what shocks should I install. Stay with the OEM shocks or put on some Rubicon takeoff shocks if I can find them.
If I buy new what brand is recommended.
Thanks
Reinen
2021 Jeep Wrangler JL Rubicon
Your shocks need to match your springs, not wheels/tires. If you have stock springs, you need stock size shocks. Shock preference is largely subjective so do your research and make your choice. But you want stock size shocks for the Sport. Length matters because they literally keep your springs from falling off at full extension.
Rubicon take-off wheels/tires don't matter. Rubicon take-off springs do matter (in which case you want stock size shocks for the 2dr Rubicon).
c20040215
Leon
Normal red body Rubicon shocks would work on your Jeep just fine. You can find them cheap everywhere. Its a bit longer gives you a bit more down travel.
Dont make it complicated.
MorrieC
Morrie
Kennewick, WA
Mercedes GLC AMG 43
Thanks everyone for the suggestions.
elwaykid
eck
ny
2021 wrangler sport S 2dr
I just put Rubicon shocks and springs on my 21 Sport s and I gained 2.5 inches .
I read it would only raise it 1.5-2
I must have measured it 10 times to make sure I was seeing right
Very happy with the change , now it’s time for new tires
Before and after pics
Jeep Wrangler JL Shock replacement IMG_2546
Jeep Wrangler JL Shock replacement IMG_2548
NINTH
Jay
Socal
2 door JL Sport
What spring numbers were the rubicon takeoffs?
AdamG
Adam
SE Michigan
2019 JLSportS - SOLD; 2026 Moab 392
Very happy with the Bilstein 5100s, can’t recommend them enough if you like a firm (not harsh) controlled ride.
Kbinspections
Rich
Kings Park NY
2019 Jeep Wrangler Moab
Is a daily driver, do you off road a lot?
What type of comfort are you looking for?
