Setting Help
johnparjr
New Caney, TX
2024 Jeep Wrangler Sahara 4xe
Was messing around with the Tazer after coming back from the dealer and my Sahara JL has always had the side marker light on and after I messed around a bit it is now off and will only come back on if the light are on. I unmarried the Tazer and it still remained off so Im not sure what's going on and its not a big deal just something that has changed. My JL was a non LED model
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
If you unmarried the Tazer it shows ups have put all back to stock, I believe the side markers are on when headlamps are on but I could be wrong, I’m not in a position to check but when I get out out work tomorrow morning I will look to see what mine do.
I also have a 2018 JLU Sahara and also have a Tazer but I don’t run any live features just changed tire size and TPMS limits and then unplugged it
WranglerMan
Will
Greenfield Indiana
@johnparjr i checked my JLU Sahara this a.m and first just unlocked using the fob and DRL,s flashed and that was it so I hit the remote start and all running lights came on then I shut it off and just used the push button to start and all lights came on including side markers so I’m guessing side markers don’t come on unless lights are turned on
I to am running a Tazer 11.08 firmware but like I said I don’t leave it plugged in
