Read at each of thee links found at this link:
https://www.jlwranglerforums.com/forum/search/4282445/?q=ecus&c[users]=Rhinebeck01&o=date
The gist is:
Always restart all ecus, twice at the end.. DO, Remember to cycle ignition key at the and and open and close the door.
@Rhinebeck:You and other's do not have to use the ZAutomotive provided switch to turn on/off SGW. That is not necessary. Just unmarry the Tazer JL and start using JSCAN.
Patrick, typically an 'Unmarry' involves both a divorce and separation. The divorce is the logical step, and the separation is the physical. I believe (if I'm understanding this properly) is that it's possible to divorce (via the unmarry operation) but stay connected so the Tazer physically remains plugged into the wire harness. Thus still bypassing the Security Gateway Module (SGW).@Rhinebeck:
I've read multiple threads here and the Tazer JL Mini instructions multiple times. Think I understand it by and large. Thanks for your previous recommendation on the SGW Extension Cable - VERY worthwhile. I made minor vehicle setting changes for now - really just setting the fogs to stay on when I turn on brights. Really got the Tazer Mini for Live Functions to remember the ESS button state and for the turn cam, hood alarm and auto park kill.
Previously purchased an OBDLink MX+ so I could potentially use JSCAN in future as well. And on that note, can you enlighten me as to what the Tazer SGW Lock setting does? (In the "other" submenu of vehicle settings.) I asked ZAutomotive but their answer still left me confused. They told me when it's set to "no" the OBD2 port can be used by diagnostic equipment to access the vehicle. Set to "yes" is the default and what it returns to when you unmarry according to ZAutomotive.
You (and others) recommend unmarrying the Tazer before making JSCAN changes (and I understand the logic of doing so). But if unmarrying puts the SGW Lock setting to "yes" (which is not the "no" setting ZAutomotive says is necessary for diagnostic equipment - like the MX+ - to access the OBD2 port) how does the unmarried Tazer still connected function as a SGW bypass?
After upgrading to the 8.4" head unit, I also discovered that without an SGW bypass of some kind (Tazer, or ECRI SGW bypass module), that the Off-Road pages do not work completely. I think 3 of the 5 gauges fail to show anything unless you have an SGW Bypass installed. Probably why many people with Tazers leave them installed for the SGW bypass functionality if nothing else.So it sounds to me the Tazer can indirectly help other tools gain access to the CAN Bus by leaving it physically plugged in (but Divorced) so as not to interfere with the other tool's logical behaviors.
Jay
Jay - thanks, I like your analogies. It appears that before using something like JSCAN you should definitely be "Divorced" - that way the tazer is still plugged in to function as the SGW bypass but you're taking care of "version control". By version control I mean being sure you're not making a change only to accidentally undo that change later. That's what would happen if you don't unmarry the tazer before you make a JSCAN change. If you don't unmarry and you make a JSCAN change and then later - maybe WAY later - you unmarry and the tazer writes back the settings as they were originally when married, which in this example was before you made the JSCAN change. Now that JSCAN change has been undone and you likely didn't intend it to be.So to be more clear maybe the terms should be:
- Married: Plugged in and (Live) like ESS disable functionality.
- Separated: Not plugged in but still married and functioning (Not Live). Settings like tire diameter has been changed. The SGW is most likely reinstalled in order to prevent fault codes.
- Divorced: Not married but still plugged in and bypassing the SGW. Just a pushbutton (or two) away from a remarry.
- Unmarried: Not Married, not plugged in, SGW connected like factor stock.
Jay
