Service Airbag
Shellbird01
Bob
Ontario Canada
2018 Wrangler JL Shara Unlimited
I might have stepped into it this time.... After vacuuming under the drivers seat I knocked the wires off the seat belt connector. I unbolted the seat and tried like heck to get the wires back in the male connector but couldn’t (what a bugger) anyway I cut the female plug and soldered the wires. Then my dash lit up like a Christmas tree, Service Air Bag, Drivers Seat belt not Fastened, Auto park disabled, stop start unavailable (I like the last 2). Ive tried to clear the code but No luck (likely not fixed).
I don’t want to take it to the stealership. I’d like to get the steering TSB but I won’t get back without them fixing it, $$$$$, they take forever and no loaner.
I’m thinking just cut the lead wires again, solder the leads to each other and clear the code. Will that close it? I don’t want to set off the air bag either.... Suggestions?
Jeep Wrangler JL Service Airbag 54C4B9A7-5FE4-4B3B-80D5-8C993074EDA0
Jeep Wrangler JL Service Airbag F3AE643F-0063-4B41-8A11-551F14904488
mwilk012
2018 Ocean Blue JLU Rubicon
Service
You probably shouldn't have messed with it. Disconnect the battery and repair the wires properly, that should clear things up.
Kajmcbride
Mammoth
2000 Jeep TJ, 2005 Dodge Ram, 2018 JLU Rubicon
I pulled the wires out of the connector when I was removing my seat and the airbag light came on on the dash. I ordered the pins from Mouser and repaired the connector and the airbag light went out.
Mouser #:571-7-1452668-1-LP
Mfr. #:7-1452668-1 (Loose Piece)
Desc.:Automotive Connectors Automotive Connectors MCON-1.2 LL (SWS) Loose Piece
4$0.20$0.80
4 Shipped​
08-Apr-20​
Mouser #:571-1718760-2
Mfr. #:1718760-2
Desc.:Automotive Connectors Automotive Connectors Tab 1.2 X 0.6 LL
4$0.81$3.24
4 Shipped​
08-Apr-20​
Shellbird01
Shellbird01
Bob
Ontario Canada
4$0.20$0.80
4 Shipped​
08-Apr-20​
Mfr. #:1718760-2
4$0.81$3.24
4 Shipped​
08-Apr-20​
Did you consider a different type of connector all together? I wasn’t impressed with the stock FCA, shouldn’t soldering directly work?
Kajmcbride
Mammoth
I am not an engineer. It seems like soldering the wires directly would work. I did think of using a Deutsch DTM Series or a Weather pack two position connector, however I wanted to keep it original.
MtCamper
Ken
NW Montana and Yuma Az
2018 JlUR White Rubi, 2022 Chevy 3500, 2016 27-5L
Retired, Snowbird
You should be able to just wire nut them together jutil you can get the parts to do it right.
Notorious
North Texas
2000 TJ Sahara
Why not?
This was not the solution.
I’m thinking just cut the lead wires again, solder the leads to each other and clear the code.... Suggestions?
Put down your tools and go find a reputable service repair shop that specializes in Wranglers if you don’t trust the dealer.
mwilk012
Service
Wranglers are no different from any other vehicle in this regard.
Shellbird01
Shellbird01
Bob
Ontario Canada
Jeep.... Put down the tools.... Jeep...
Well Jeep ownership is an inclusive club
Dan M.
Albany NY
2020 sport (2 door)
If anybody can figure out how to disable auto park and Start stop by messing with the wires under the seat, please let me know!!!
mwilk012
Service
if you’re okay with disabling the drivers seat belt auto tensioner and airbag, go ahead and unplug it. Or, you can let the vehicle do what it is supposed to do.
Shellbird01
Shellbird01
Bob
Ontario Canada
Well.... I disconnected the battery, soldered the wires, but the light is still on. Should it clear on its own, I tried with an Innova also. I’m thinking the buckle housing might need replaced. Is there a test for this?
Thanks
Shellbird01
Shellbird01
Bob
Ontario Canada
Well... If anyone is interested I finally got the parts for the seat belt and the harness under the seat. I disconnected the neutral wires from the battery, pulled out the seat, replace the parts and all is working fine no more error codes
