Seat Jackers Review - Dramatic Improvement
XYJGuy
SG
San Clemente, CA
BMW 430i, Acura MDX, 2 Hyundai Tuscons, JL Willys
Retired Technology Sales.
I thought I would post a quick review of Seat Jackers by Desert Does It. I am 6'2" with a 34" inseam and found my JL 2 door very uncomfortable to drive with no thigh support. I considered seat extenders but I did not get verification they would work in a 2 door. I was also concerned that if I extended to far, my arms would not be comfortable reaching for the steering wheel (I currently have it at full telescope and it's perfect). Thus, I purchased the Seat Jackers.
The Seat Jackers that I used were the adjustable version that includes the .75 inch block with the additional .25 inch top plate for a full 1 inch lift. According the fit guide on their site, they recommended the fixed front seat jackers but I did not want to go that high in case other family members wanted to drive the Jeep. It turns out, the adjustable work just fine. I was actually skeptical when making the purchase, but once I got them installed, I knew immediately that they solved the problem! I highly recommend these for tall drivers. I still have head room, but having an average length torso, I did not have a head room problem to begin with. It should be noted that I keep the seat in the lowest position.
A couple of negatives are:
1. The instructions. I found them poorly written and incorrect at one step. There were also no specific videos available for the "Seat Jackers".
2. The inner block next to the transmission tunnel could have been machined better to fit the new tilt angle of the seat rails. That said, they seem to work.
I know that some forum members here are using washers and for them that has worked very well. That said, if you are not a DIY person and want a fairly inexpensive solution to a big problem, this could be it.
Ct_Formula
Orange Ct
2021 Rubicon JL, 2011 JK Sahara
Self Employed
I can't wait to try them! Thanks for the info
Pinion
Rob
Hull, MA
1971 FJ40, 22 Rubicon Unlimited
Project Manager
I don't even have my Jeep yet and I know I will need something. We have similar dimensions, so your review is very helpful.
Ct_Formula
Orange Ct
Self Employed
Same here, mines on order 186 days now and I already have my Seat Jackers in waiting for it
openingshok
Kansas
2021 Grand Cherokee Limited X | 2024 JLUR 2.0T AT
Headshot Photographer
I am 6’ with a 32” inseam, the outside of the fixed jacker limit. I purchased and installed the fixed and found it was a tad too much. With a manual tranny I couldn’t rest my heel on the floor while shifting. I sent them back and replaced with the adjustable. With the spacer block installed it is a perfect fit. HUGE difference.
Terpsmandan
Penn Yan
I have them in both hers and mine. Huge difference in comfort, especially long haul. I am 5'10" with a 32 inseam and the fixed jackers work great.
Terpsmandan
Penn Yan
1.25"
Hostile17
Angela
Missouri
2021 JLU Willy's
Has anyone super short used these? I am very short (under 5ft) and find my legs aren't supported well, which leads to discomfort and pain. Unsure if lifting the front of the seat would provide better support or more frustrations. These are pretty pricey to try and hate.
XYJGuy
XYJGuy
SG
San Clemente, CA
I am not 100% sure, but I believe they would help. I am guessing your seat is forward and bottomed out so the nose is lowered taking away your support. I bought mine used from someone that got two from the manufacturer. So it might be worth checking the used market, or if you try them and they surprisingly do not work for you, you can resell them so its not a complete loss. Either way, good luck.
stino
Justin
Redondo Beach, CA
2018 JLR
I think these would be a good upgrade for anyone, I never liked the wrangler's seating position.
