Sahara with soft top height
Newdeal
Andover, MA
2019 Sahara
Does anyone know the height of a Sahara with a soft top? Alternatively, how much higher is the soft top that the hard top? I have a clearance issue with my garage. I currently have a Sahara with a hard top that fits but there is only about 3” to spare. I would like to install a factory premium soft top but I’m not sure if it will fit. Thanks.
robaw
Rob
Iowa
I have my soft top on at the moment... I measured at the high point (around the area behind the rear door) and the top goes about 6" above the top of that door. Don't know how high the hard top sits, but probably only a few inches less than that.
robaw
Rob
Iowa
It’s definitely not 3” taller.
I guess we'll see (maybe). The soft top is definitely not flat like the hard top, has decent amount of loft. Might be 3", but even if it was only 1.5-2" not sure I'd want to chance scraping it.
Newdeal
Andover, MA
2019 Sahara
Thanks
SouthLeb
Rame
Knoxville
19 JLUS punk'n
I measured 74.75 inches with premium soft top and AT tires
Worse case you can air down your tires before parking in garage :LOL:
Newdeal
Andover, MA
2019 Sahara
Or put the top down befor I go in, I guess.
Thanks
RichD
Rich
Boston
2018 Sport S
I had the same problem Steve. I have about 3" of clearance to the top of the garage door. I was able to raise the motor and track to at least get that out of the way. No lift kit or larger tires in in my future! :crying:
Newdeal
Andover, MA
2019 Sahara
Did you end getting the soft top anyways?
