South Carolina Rust on Suspension
Jeepgal
Kimberly
SC
2017 Jeep Wrangler
Can I get your opinion on the rust found in these pictures? Is this surface rust or something to be concerned about.
Jeep Wrangler JL Rust on Suspension 0_da809423-b8ea-4267-a6cd-c1ef92c6938c
Jeep Wrangler JL Rust on Suspension 0_5e4ee3a8-63e6-48aa-9e22-c1af90c403a2
Jeep Wrangler JL Rust on Suspension 0_43d5e04d-353b-4e62-ba01-3c300c2fd462
Jeep Wrangler JL Rust on Suspension 0_fcaae172-72e6-4b64-b579-bc0c6f21989f
Jeep Wrangler JL Rust on Suspension 0_105bf6f1-8cec-4085-a91c-761a82c0a2f6
CarbonSteel
While potentially only light rust now, it will not remain that way if not treated and/or protection applied. It all depends on how long you intend to keep the vehicle as to whether or not something should be done. Unchecked and in unfavorable environmental conditions, rust will spread and become detrimental.
Jeepgal
Kimberly
SC
2017 Jeep Wrangler
My opinion, surface rust. Nothing to worry about, and normal in areas that salt their roads.
Thank you. Let me add that this is a 2017 wrangler with 16000 miles on it.
Swagger
Michigan
While CarbonSteel is correct about rust in general, the areas you showed (exhaust bolt, shocks) should not concern you. Shocks wear out over time and are replaced, and the exhaust bolts are normal steel (not stainless like the rest of the exhaust). Most people are more concerned with rust on the frame welds, which could cause structural failure if neglected. Most automakers cheap out as far a corrosion protection for the parts you showed because they are not readily visible on most vehicles. Shocks are more visible on Jeeps, though, which is why the high end shock absorbers are made to look pretty and may have better protection.
Jeepgal
Kimberly
SC
2017 Jeep Wrangler
Thank you. I appreciate your input. Can you see any reason for concern on the frame?
Jeepgal
Kimberly
SC
2017 Jeep Wrangler
Thank you. What type of protection or coating do you recommend? Have any idea of cost involved and who around my area could do this.
Swagger
Michigan
I can't tell about the frame from the pictures you show, but there are places that will undercoat your jeep. Some people are very particular about their undercarriage, and touch things up with flat black paint. I haven't used it, but some use a product called fluid film to protect their frame. I'm considering using it on mine.
oceanblue2019
Northern Arizona
2019 JLUR 2.0L Auto
Consultant
Fluid film works pretty good. The only issue is it's not great if you drive on the beach or sand dunes. It tends to stay a bit sticky and the sand is drawn to it.
CarbonSteel
I concur with @Swagger, Fluid Film should be readily available to use otherwise, there are professional rust proofing places.
While the vast majority of the rust that you have indicated are on pieces that could be easily replaced, you do have surface rust starting on parts of the main frame. Take a look at the frame at upper part of the shock. Light rust now, but it will accelerate over time. If your city or state uses salt and/or anti-ice solutions on the highways during the winter this will only compound the problem.
Jeepgal
Kimberly
SC
2017 Jeep Wrangler
You take it on the beach often? If so make sure to rinse it immediately as the salt you pickup is really nasty.
This Jeep comes from NJ and I'm in SC. This is one I am deciding on purchasing. I just want to make sure it will not be a rust problem.
ChattVol
Tennessee
JLU 4 door
I'd take care of it now while it's not bad and an easy DIY project. Lightly sand the rust where possible(I use 120 grit) and clean the areas and let it dry. Apply POR 15 brush on paint to rust areas and any other areas you want to protect. It's strong stuff...so wear gloves and put down a drop cloth. It's next next to impossible to get out of concrete.(don't ask me how I know)
Renegade
Zac
Signal Mountain, TN
ā€˜20 JT
If you don’t have to buy a rusty Jeep from the ā€œsalt beltā€, don’t. There are plenty of rust free southern Jeeps out there.
Hey ChattVol, how’s that new baby?
