Sport S Lift Options - Leveling or 2.5”
Jeepster2018
Mid Atlantic US
VW GTI
With a 2dr Sport S, would doing a 2-2.5” lift with 33” wheels be about the right lift height?
Something like the Rough Country 2.5” Suspension Lift Kit w/shocks or Teraflec 2.5” Lift Kit Without Shocks?
Or something like the Teraflex Leveling Kit w/o shocks giving 1-2” more than sufficient?
Moe
Moe
SW Ohio
F250, Fit
Retired X 2 = 23 years USAF + 23 years IT
Some of the best looking JKs I've seen with 33s (285/70R17) use nothing more than the Teraflex Leveling Kit (a pair of 2" coil spacers up front with a pair of longer sway bar links, and a pair of 1" coil spacers in the rear)--average 1-1/2". All it does is raise where the vehicle rides within the stock suspension travel (meaning more compression travel and less rebound/extension travel).
Moe
Moe
SW Ohio
F250, Fit
I've always suspected all a JK with 33s needs are 1" spacers up front with the stock disconnects--nothing in the rear. But I don't know that for sure.
The height rating of lift kits with replacement springs assumes one is running heavy metal bumpers, a winch, and a load in the back. On a stock vehicle it often lifts much more than the rating.
Jeepster2018
Jeepster2018
Mid Atlantic US
VW GTI
Something like this?
Does it make for a stiffer ride then?
Jeepster2018
Jeepster2018
Mid Atlantic US
VW GTI
So typically a 2.5” Lift would be a little too much then?
Onlylive1
North Carolina
2015 JK Unlimited
I have a 2015 JKU with a Teraflex leveling kit and 33s. I love the look and it doesn't impact the ride at all.
I also ran 33's with no leveling kit without a problem but I think the stance looks so much better with the leveling kit.
Jeepster2018
Jeepster2018
Mid Atlantic US
VW GTI
Definitely agree with the stance with the levelling kit compared to without.
Any chance you have any before and after pics?
So no real need to do more than a levelling kit? Like a 2.5" kit would be overkill?
Onlylive1
North Carolina
2015 JK Unlimited
I'll have to look and see if I have any before and after photos... I think the 2.5 might be overkill unless you plan to head towards 35s in the future.
Moe
Moe
SW Ohio
F250, Fit
Most of the best forum pictures worldwide were lost to the PhotoBucket Blackmail Block. That includes the ones I went looking to show you.
The Teraflex kit is IMO at the upper limit of tasteful with 33s. Go higher and it looks like you could afford a lift but not the tires and wheels to go under it. You also start running into more complexity. A "2.5 inch" kit would likely lift a plastic or sheetmetal bumper Jeep 3.5" or more.
Moe
Moe
SW Ohio
F250, Fit
Search for pictures with these terms:
before and leveling site:jkforum.com
before and leveling site:wranglerforum.com
before and leveling site:jeepforun.com
Jeepster2018
Jeepster2018
Mid Atlantic US
VW GTI
Looks good. So it added about 2" in the front an 1" in the rear?
What is the longevity of the Tera levelling kit? Does it need to be replaced at some point?
Here's a before and after picture. I swapped rims/tire too but still 33s.
