arod0915
Hello, first time posting on the Forum.
I recently completed the Rugged Ridge Fender Chop with DRLs on a 2020 Rubicon that does not have the LED option from factory. I have seen this mod accomplished on several YouTube channels and it seemed straight forward, plug in the harness and your done. The harness received in my kit has an inline relay for each DRL with instruction to connect a certain way depending on the Vehicles configuration, Factory LED, Standard Non-LED, and LED without Switchback. As previously stated my Vehicle is a Non-LED Rubicon so I connected per the instructions , the DRL's do not illuminate when the vehicle is on unless the Light Control switch is in an ON position. I called Rugged Ridge and after 3 weeks of getting the run around a tech told me today that I need to flash the ECU to activate the LED DRL? That makes no sense since the DRL feature worked fine prior to the mod and they have a specific connection for Non-LED Vehicles.
1) Has anyone installed the Rugged Ridge DRLs with the Rely in the harness and is having this issue?
2) Does anyone know what connection will bypass the relay?
Any input would be greatly appreciated, I have attached a picture of the Harness and the Rugged Ridge termination sheet for reference.
