Rugged Ridge DRL Relay Issue
arod0915
Alex
Miami
2020 Wrangler Rubicon JL
Hello, first time posting on the Forum.
I recently completed the Rugged Ridge Fender Chop with DRLs on a 2020 Rubicon that does not have the LED option from factory. I have seen this mod accomplished on several YouTube channels and it seemed straight forward, plug in the harness and your done. The harness received in my kit has an inline relay for each DRL with instruction to connect a certain way depending on the Vehicles configuration, Factory LED, Standard Non-LED, and LED without Switchback. As previously stated my Vehicle is a Non-LED Rubicon so I connected per the instructions , the DRL's do not illuminate when the vehicle is on unless the Light Control switch is in an ON position. I called Rugged Ridge and after 3 weeks of getting the run around a tech told me today that I need to flash the ECU to activate the LED DRL? That makes no sense since the DRL feature worked fine prior to the mod and they have a specific connection for Non-LED Vehicles.
1) Has anyone installed the Rugged Ridge DRLs with the Rely in the harness and is having this issue?
2) Does anyone know what connection will bypass the relay?
Any input would be greatly appreciated, I have attached a picture of the Harness and the Rugged Ridge termination sheet for reference.
Jeep Wrangler JL Rugged Ridge DRL Relay Issue IMG_0416
South Carolina
revkit.com
2020 Jeep Wrangler Unlimited Rubicon
Any updates on this? I have a set of these brackets on order for my JLUR (same as yours), and I'm curious if I'm going to have any issues going from halogen to LED DRL's.
arod0915
arod0915
Alex
Miami
Chris, unfortunately your the first person to respond to the thread and I am done dealing with Rugged Ridge. I have been meaning to reconnect the lights and see if that helps but have not had the time. Right now they work fine as turn signals and when the headlamps are on they illuminate like advertised, but as DRLs they are still INOP. If I get any additional info or fine a fix I will update the post. Good luck and hopefully your lights will not come with the Relay!
South Carolina
revkit.com
Thanks for the reply. I ordered mine a few weeks ago, and the order still said it was pending. I emailed them a couple of times with no response, so I finally called this morning. I was told that there is no ETA on my brackets because the materials are back-ordered indefinitely. I ended up canceling my order, and I'm going to go with the chop brackets from American Adventure Lab. Hopefully, you can find some sort of resolution to the issues you're having.
arod0915
arod0915
Alex
Miami
Good luck with the Adventure Lab set up, I've heard good things about their product.
OffroadCalling77
Josiah
Brea, CA
21 Rubicon 392, 21 Sahara Altitude
Biz Owner
12-15 weeks back ordered FYI. Cancelled after 10 weeks and went with Quake LEDs. I’ll let you know how I like them after install next week.
OffroadCalling77
Josiah
Brea, CA
Biz Owner
I look the physical look of these Rugged Ridge units but the lack of support and problems your having making me satisfied I chose Quake.
arod0915
arod0915
Alex
Miami
Hello Josiah, I am not unhappy with the actual units or the installation of the support structure. The Rugged Ridge units have held up well so far. My only issue is with the Electrical connection and their lack of support. Anyways, good luck and I may have to look into an alternate light eventually if I cannot get the DRL's to work properly.
920Jeep
Felipe
Wisconsin
2021 Jeep wrangler
Hey I just got these in and I’m having the same issue. Did you find out what the problem was?
arod0915
arod0915
Alex
Miami
Hello Felipe, sorry for the delay in responding. I actually got the DRL's to work but I had to use the OBD JSCAN app and a blue tooth OBD transmitter to activate the LED DRL Fnction, which is not how the lights are advertised. Anyways, I actually activated the Amber portion LEDs which look good as a DRL and it is different from most. When the lights are on the DRLs light up white as they should. I didn't change any wiring which I thought was strange but somehow it works. Good Luck!
ScotM
Scot
Southern California
2022 Jeep Willy's JL 2 Door
I set my non led sport up using the
I have a sport non led. I changed the settings in Jscan to LED, set up the wiring using the top wiring diagram, and everything works. I noticed the relay is huge and noisy, so I decided to see if it would work without the relay. Everything functions fine. I wish someone could tell me if it is ok to remove the relay out of the picture, as it is giant and noisy. If I am correct, the relay is just a simple on off switch for controlling the turn signal, which the jeep is managing to do without the provided relay. Any insight would be appreciated.
jetpuck73
Trenton, MI
2018 Jeep Wrangler Rubicon Unlimited
I removed the relay for the same reason, no issues. I have been running like this for two years now.
NeotranZ
Doug
San Diego
22 JLR
Did you end you just disconnecting the relay from the harness? Did you need to do anything with the wires in the relay plug attached to the harness?
I just wired mine up (JLR LEDs) and I can only get amber DRL if I use my tazer to set DRL to turn. Also those relays are super loud, would t mind deleting them myself. I used some thick shrink wrap and spent way too much time installing these so not super excite to tear it all open again.
jetpuck73
Trenton, MI
I can’t remember but I think that I just left it as is.
NeotranZ
Doug
San Diego
22 JLR
Whelp I confirmed it does work the same w/o the relay but I still cannot get the white light to work as DRL. I tried disabling LED and tried the other wiring options, not sure if it’s a factory LED thing or what… sad. I’ll try calling them tomorrow as see where I get.
