Rubicon x soft thud
dmgarcia2197
Miguel
Ohio
2023 Jeep Wrangler Rubicon
Hi! I bought a brand new a 2025 Rubicon x with xtreme recon. It only has 200 miles on it right now. Every time I turn on the vehicle and start driving it i notice a single light thud/thump when I press the gas and start rolling. It only happens when the car is driven from being off. But if I parked it and drive it again it doesn’t happen. I have to switch the vehicle off and on again for this thing to occur. Is this normal?
AmericanPatriot100
Kitsap Co
2025 Wrangler Sport JL
Not to be crass on your first post but does that seem normal for a 2025 with 200 miles to be doing that? I’m going to assume it’s automatic. Is it V6 or 2.0L? Is it like a hesitation or like your running something over or like a backfire? And does it happen every time the car is restarted or just the first initial drive from being parked say over night or after work?
AmericanPatriot100
Kitsap Co
Mine is a 2025 manual V6 and while driving, around 1700-2000rpm under light load there’s quite a few of us who get what feels like a backfire/hesitation but there are no engine codes that pop up when this happens. But it’s consistent and always between this specific rpm range up to about 4th gear. There are a few automatics that have this issue also. Well not so much an issue more of an annoyance.
dmgarcia2197
Miguel
Ohio
Yes its automatic with 2.0L. It feels like i run over something but its very light and you need to pay attention to notice it. Its also happening as soon as I restart the car. But doesn’t happen anymore of i dont turn the car off.
dmgarcia2197
Miguel
Ohio
It also happens in first gear. Its like a first thud momets after I press the throttle. Its doesnt happen if i just letting the car crawl/cruise without gas
yokramer
Snark Incarnate
Is it when there is still a high idle from start up? Give it some time to let the engine settle down to the normal idle before putting it into gear and see if it happens.
dmgarcia2197
Miguel
Ohio
This is just normal drivetrain slack lockup. Don't worry about it.
I was actually thinking if this is just a normal drivetrain lash. Cos it always happen even if i warm up the car. It happens every restart
dmgarcia2197
Miguel
Ohio
It happens every restart even if i let the car settle or warm up. After the thud happens it doesn’t happen until i turn the car off and drive it again
yokramer
Snark Incarnate
Interesting then yea Im stumped. I do get a clunk when I am impatient and just dump it in gear after a cold start but thats to be expected.
dmgarcia2197
Miguel
Ohio
I don’t get a clunk switching gear its when i start driving when i press the gas
