Rubicon - Slip Yoke or Fixed
BellValleyAT
Greg
Rhode Island
2025 JLUR
Does the JL Rubicon TCase have a slip yoke rear output or fixed?
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
They use Rzeppa joints in the JL at the transfer case and rear axle. The front axle has a single U-joint. Rzeppas are CV joints. Though they can't tolerate as much angle as a double cardan joint. And they're weaker than they should be. So upgrading to U-joints is a good idea if you go over 2-3" of lift. Lots of places sell upgrade kits.
Zandcwhite
Zach
Patterson, ca
2019 jlur
The rear is good at any reasonable lift height. The front runs into issues on droop. Shocks over 29" extended length are problematic.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
2 door does tend to bind at lower lift heights than a 4 door. The rear driveshaft is so much shorter on the 2dr.
BellValleyAT
Greg
Rhode Island
2025 JLUR
Appreciate it!
Zandcwhite
Zach
Patterson, ca
2019 jlur
But where is that cutoff? I've wheeled with several 3" lifted JLs on stock shafts. Which is why I said reasonable lift heights. You don't see too many 4"+ lifted JLs and they'd look silly if they weren't on 40"+ tires. At that point you're probably into 60s and the stock shafts are long gone anyway. I know for a fact on the JLUR that the stock shaft is fine on 31" extended length shocks at full droop in the rear.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
4 doors can flex a lot more than the 2 doors without binding. The axle moves just as much but with the longer driveshaft the angles never get too far.
Most 4 doors don't push the angle too far.
And it's not so much the lift height as the droop distance, especially on the front axle. And there's way too many variables in that equation. Shock travel, whether you outboard the lower shock mount to eliminate binding, the joints in your control arms, etc.
Zandcwhite
Zach
Patterson, ca
2019 jlur
I agree, but 2dr or 4dr the front is the same. Obviously the rear on a 2dr will bind before the 4dr, but I haven't seen it as an issue with any "normal" builds. Most 2dr guys won't go past 37s and 3" and at that point it didn't seem to be an issue.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Yes. Fronts are virtually the same 2dr to 4dr.
I added the metalcloak shock relocation kit and longer travel shocks on mine. 2.5" lift with Clayton arms and 37s. My front Rzeppa showed signs of being over extended when I swapped out for a Tom Woods front driveshaft.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Here's the video we did on my front driveshaft swap. I show the Rzeppa next to the double cardan joint in here.
Nokones
Kenny
Sun City West, AZ
23 Rubi, 21 Silverado, 13 Grand Sport, Cayman GTS,
Unemployed For The Rest Of My Life from a career of spreading love, cheer, and joy to lots of special individuals that were asking for attention..
I went with the Tom Woods 1350 drive shafts and the rear is a Double Cardan. You need to make sure that the rear driveshaft angle is no more than two degrees different than the Pinion Angle to eliminate any low speed harmonics.
Adjustable control arms and Track Bar mostly likely may come into play in order to adjust your angle.
Terrymo
Terry
2023 JLURXR 3.6 ET
I see some people putting RTV on the splines of the yoke, and some people putting it on the contact surface of the nut. Pros and cons of each? Why not both?
Also I see some people only using blue loctite and some using red. Opinions? Thanks
Terrymo
Terry
2023 JLURXR 3.6 ET
@grimmjeeper regarding my previous post, looking at Tom Woods instructions I see they suggest RTV on the splines as well.
